Page 12 of 139 FirstFirst ... 210111213142262112 ... LastLast
Results 166 to 180 of 2085
  1. #166
    Eltham vic
    hi andy
    what area are you in
    ian
  2. #167
    Junior Member Automotive Encyclopaedia Big rob's Avatar
    I'm just wondering if anyone could give me some advice.
    I bought some side skirts for my GZ20 soarer but in places they are a little cracked or chipped. I would like to repair them or totally repaint them, I have friend who resprayed his Nissan 240k from metal up but has never played with the ABS like material these skirts are made from.
    Has anyone delt with something like this? He mentioned we may have to add some flexour or sometime like that to increase the flexablity of the pain.
    BTW the colour is Toyota super white.
    I'll try and get some picks up to show the areas that need to be preaired.
    Rob
  3. #168
    Yes, you will need a flexible paint (or flexibility additive), and you will need to plastic prime anything that goes back to plastic before you fill prime. After you have primed it, other than adding the flexibility stuff, its the same as anything else to paint.
  4. #169
    Cheers, plastic prime = primer that sticks to plastic and regular primer?
  5. #170
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    Quote Originally Posted by Neverland
    was told yesterday that paint shop open today 8am-12pm
    arrived at 9:30 said here is the colour code ...
    "oh sorry can't mix that today Dupont s colour matching site isn't open on the wkends.. wtf
    ..now I have to wait till next weekend gggrrrrrrrrr :|
    hi neverland, where are you getting it sprayed?
    1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
    2. Don't argue with an idiot; people watching may not be able to tell the difference
  6. #171
    is damn glad to meet ya. Domestic Engineer andy's Avatar
    Quote Originally Posted by ian
    hi andy
    ian
    check pm
    you can do anything at http://www.zombo.com/
    the only limitation is yourself
  7. #172
    well i got the paint this arvo
    he fixed it. its NEARLY what i wanted. ive given up. close enough. the one i wanted was brighter and it stood out. what i got is a tiny bit darker, but looks like its got too much white cos its sorta dull
    cant wait to finish this off. then pics.
  8. #173
    plastic prime = use plastic primer (A special type of primer that sticks to plastic)
    If you were doing bare metal you would etch prime... same situation, it gives a base for the fill primer to stick to.
  9. #174
    south austraila
    Dont forget that paint looks different in the tin Andy... they dry a different shade to what they are when wet. Also it could need more mixing. Best thing to do would have been to get it home, test it on a scrap panel (or fuel flap if you have one), let it dry, then check, in both shade and bright light, against the sample. Your gonna look like a dick if the colour matching bloke turns up and tells you that
    Just a tip.. on getting right color match... ( my paint shop days)
    As paint will dry a different shade to what they are when wet..
    Use an old "P" plate (magnetic type) spray "P" plate let it dry then throw it at car (random like) ..
    If it disappear's, then paint match is good ..
    If it still stand's out .. get paint retinted...
    Project: '82, GA61 XX
  10. #175
    Eltham vic
    good tip ga61xx
    far better than getting an uniinterested apprentice to hold up a card against it to check the match
    sack the apprentice now lol
    ian
  11. #176
    south austraila
    I worked in a Paint & panel shop for a few years .. & that's what we did... "P" plate color match..
  12. #177
    Junior Member Grease Monkey Night Rider-TA23's Avatar
    Another question about the windows, how did you remove the chrome surround?? And how hard is it to do without bending it??
    Jarrod
  13. #178
    Eltham vic
    wich windows jarrod
    ian
  14. #179
    Junior Member Grease Monkey Neverland's Avatar
    Nov 2007
    Quote Originally Posted by Night Rider-TA23
    Jarrod
    My trims were I spose a bit easier. the fact that the rubbers were perished meant that the trim wasn't seated properly. Also the person before me had... wait for it..... SCREWED all 4 corners down becuase they where lifting!!!!! the tenacity!!!
    I'm pretty sure you lift gently and slide? Please correctly if I'm wrong
  15. #180
    Windscreen trims?? You need to lever them at the clips. Use a rag and a broad bladed prybar (made for removing trim) that has an angled head. Get in under the outside part of the trim, and rock the prybar gently back. The rag is there to protect both the paint and the trim, so use a soft cotton one, and put it over the entire prybar head.
    GA61xx... I like your P plate matching method... nice.
    Last Post: 06-01-2010, 08:34 PM
    Last Post: 22-09-2007, 11:52 PM
    Last Post: 11-01-2006, 09:53 AM
