Page 17 of 21 FirstFirst ... 71516171819 ... LastLast
Results 241 to 255 of 301
Thread: Standard 1G-GTE Dyno.
  1. #241
    Mar 2008
    inner west syd now!
    Default Re: Standard 1G-GTE Dyno.
    Quote Originally Posted by JustCallMeOrlando
    Yes it does. It throws a code for it and you get the usual "I feel like I broke" it jolt.
    mmm i had that pretty scary one night... just coming home from my missus house round 1am....going through the industrial area...big dori happenning......coming on main industrial road...i planted it, kicked back into first.....booost....PING!!!!???? WTF was that....engine check light....no power.....light goes off continue driving......STALL!!!! stopped in the midle of the road.
    START PANICKING NOW!!!
    wouldnt [email protected] the hood....relief......blew the intake pipe CLEAN off the motor....BOV hit the alternator...causing the ping noise....relief, jammed the pipe back in...drove home fixed it up!!
    Fuel cut/Boost cut is basically all the same, they all = NO POWER!!! never hit rpm limit....its auto...so it just shifts!!!!
  2. #242
    Quote Originally Posted by woggin
    and here i was, hoping you were actually smarter than some of your posts
    sik bro, fooly sik
  3. #243
    Mar 2008
    inner west syd now!
    me, smart, hehehe, your funny!!
  4. #244
    that's ok.. i know i'm not funny
  5. #245
    Nov 2007
    About to set the timing on my stock 1g-gte. Should I keep it at 10 Degree's or would I get any power increases from advancing it further?
    Running on 91 Pump Gas and Standard Boost, 7 PSI I think.
  6. #246
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    with 20yo motors, just note that when doing timing, the timing marks really dont apply anymore as they did when the engine was new, as the cams, valves, lifters etc are all get worn away. When doing timing you'll have to adjust it so it runs smooth.
  7. #247
    Nov 2007
    Engine is in pretty good cond, only done 60,000k's, just wondering if it's ok to advance timing a bit further on stock IC and 92 RON.
  8. #248
    Err, don't run it on 91 pump gas dude, use one of the 98RON fuels like BP Ultimate...
  9. #249
    60,000ks, one owner never beached! never wound back before it left japan!
    as JCMO says use 98 octane, jap fuel standard is 100ron so 91 will be making it cry.
    RA23 - Twincharged
    JZZ20 - Daily
  10. #250
    Nov 2007
    Thanks, I just cant help being cheap at times
    Would I be allright with 91 or is it really not reccomended, by the way dont Jap and Australian's use a different system when measuring the octane rating? Have seen this mentioned many times.
    In that case when advancing the timing, what would you reccomend if I use 95 or 98 RON, with 7 PSI and stock IC.
  11. #251
    I ran a 5 degree advance using 98 ron with my 7mgte, this was done on a dyno to check for pinging.
    91 wont be alright, it would be pinging its ass off all the time.
    RA23 - Twincharged
    JZZ20 - Daily
  12. #252
    Nov 2007
    Hi Kedderz,
    What readings did you get on the dyno with 5 degree's advance, and what gains did you get, AFR's too. Do you have any dyno sheets?
    Thanks.
  13. #253
    This was for a 7mgte, it does not apply to you.
    Dont play with timing unless its on a dyno mate, especially running 91 octane fuel.
    You cant hear some detonation and it doesnt take long for it to go bang.
    RA23 - Twincharged
    JZZ20 - Daily
  14. #254
    Nov 2007
    Yeah best not to mess around with it, and yeah I'd rather use 95 or 98.
    Usually how much would the dyno operator charge you?
    Thanks.
  15. #255
    Cant comment on WA shops, ring a few and ask, but theres hardly any benefits unless you have some control over AFR's.
    Bottom line, the 1ggte in a z20 soarer is slow and will always be slow, its simply not powerful enough for a boat that big.
    RA23 - Twincharged
    JZZ20 - Daily
  1. *** Dyno Day History Lesson ***
    Last Post: 09-04-2013, 09:50 AM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 01:32 PM
  3. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 11:46 PM
  4. std altezza 3sge on chassis dyno
    By Celica RA45 in forum Tech and Conversions
    Last Post: 29-12-2005, 01:06 AM
