Page 19 of 21 FirstFirst ... 91718192021 LastLast
Results 271 to 285 of 301
Thread: Standard 1G-GTE Dyno.
  1. #271
    Default Re: Standard 1G-GTE Dyno.
    Gttwinturbomk3 what "performance head studs" are you using?
    RA23 - Twincharged
    JZZ20 - Daily
  2. #272
    2j arp studs fit
    cheers steve,
    1ggte, 11.22 @122mph
  3. #273
    what steve said, they 2jz studs fit top and bottom end
    KE38 - 2TG
    MS65 - 1UZ
  4. #274
    will twist my nipples and call me shane, 2jz ones it is.
    Still need a decent pair of cams otherwise my forged engine is set.
    RA23 - Twincharged
    JZZ20 - Daily
  5. #275
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    Quote Originally Posted by Kedderz View Post
    I dont know what brand exactly we used, but they where adaptable, yeah arp dont make any for the 1ggte so we had to look at other options and found some others that fitted. They proberly were arp ones for the 2jz or 7m, good fastners anyways.
    The ring lands in these are very small so there isnt much room for added lubrication up the revs, so its best to always use real good rings in these the chrome ones that i used can be twisted 360 degrees and still not break or snap. The pistons are not bad at all and capable of lots of horsepower its just getting them to seal is very important.
  6. #276
    Aug 2009
    I know the info is most likely somewhere in here already.
    But I wanna know what sort of boost I should be able to run safely.
    The car has a 2 3/4" exhaust, larger front mount, but I assume the rest is stock.
    I will be running a greddy EBC. Just trying to work out what boost to set it to.
    Blair.
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
  7. #277
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    I ran 15psi daily with my gen3 turbos, gen3 block and gen2 head (it was the bastard child of several 1G's..)
    Don't expect too much from the engine.
  8. #278
    Aug 2009
    Mines a gen 2, I was thinking about dailying it with 10-12 psi and when I wanna have a bit more fun increase it a bit more to 15psi?
  9. #279
    Running my gen2 turbos at 15psi resulted in them failing the day after, oil leaked past the seals which were evidently busted. YMMV.
    The gen3's worked great - find some if you can. They need a small amount of modification to get them to fix but nothing you couldn't do with a dremel or round file.
  10. #280
    Agreed, gen3 turbos can take alot more boost (18psi in my case). Gen2 are less forgiving from what i have read so keep it at 11psi max.
    RA23 - Twincharged
    JZZ20 - Daily
  11. #281
    Aug 2009
    Would changing to jz turbo's be better/possible without spending too much?
  12. #282
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    to put it bluntly no. flanges,oil feeds,drains and water lines are different.
  13. #283
    not worth it, go single tubro.
    RA23 - Twincharged
    JZZ20 - Daily
  14. #284
    Aug 2009
    yeah thats what i was thinking. Thanks for the help though
  15. #285
    Junior Member Backyard Mechanic SIKTOY's Avatar
    Quote Originally Posted by Blair View Post
    Blair.
    Blair
    I was running 18psi all the time in mine and it ran a treat I tryed to boost it to 20 but the stock turbos would run out of puff and come back to 18 at full revs
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
  1. *** Dyno Day History Lesson ***
    Last Post: 09-04-2013, 09:50 AM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 01:32 PM
  3. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 11:46 PM
  4. std altezza 3sge on chassis dyno
    By Celica RA45 in forum Tech and Conversions
    Last Post: 29-12-2005, 01:06 AM
