Page 18 of 21 FirstFirst ... 81617181920 ... LastLast
Results 256 to 270 of 301
Thread: Standard 1G-GTE Dyno.
  1. #256
    Nov 2007
    Default Re: Standard 1G-GTE Dyno.
    Your right, I'm just trying to get the most of what I got.
    So you recon not worth it unless I get my hands on a AFC/SAFC ?
  2. #257
    If it was me, I would fit a fuel computer of sorts, boost controller and put it on a dyno and tune for 15 or so PSI. This will be a safe figure and you could also fit a better intercooler at the same time for an even larger gain.
    RA23 - Twincharged
    JZZ20 - Daily
  3. #258
    Nov 2007
    Cheers, thats the way I'll go.
    You recon a JZA70 intercooler should fit fine behind the stock bar without cutting?
  4. #259
    Junior Member Grease Monkey Brad-KE35's Avatar
    lol gavatron
    1977 Toyota Corolla KE35 - Undergoing 4AGTE transplant.
    1994 Ford Falcon Pedovan - Rape Dungeon
  5. #260
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    aye fellas
    A while ago i fitted a rather cheap and nasty boost controller, its on the car for the time being until i can rake up some more cash for a decent ebc something like what Nathan's got sounds good to me but there about $600-$700 so havnt got onto it yet, but will do soon.
    The controller im using atm is a simple flick the switch to high boost from standard, which consists of a very simple but not very effective electronic solenoid to control the boost.
    On the dyno lately with it i have found that im getting good results of around 170kws on the wheels at just under 14psi, but for some reason its dropping off to only 9psi when im at that peak power figure, ive put the sheet up below?
    I know that the controller isnt decent but im thinking that there must be something else going on here to make it drop boost by nearly 5psi. It was also quite hot on the day with 26 degrees celcius in the dyno cell so its certainly making good power its another one of these engines i think that goes hard with stock twins.
    Has anybody here had major boost drop with there controllers and or taps and do you think that maybe its leaking some where else like the bov? i cant think of anything else for this its a little odd
  6. #261
    1G beliver Backyard Mechanic BLK1g-gte's Avatar
    Most 1ggte with stock setup drop boost up top, thats one of the major issues. Some say its the AFM other the restriction in the inteake piping, i too would like to know the definet answer. I did manage to eliminate this with a EBC as it only drops 1-2psi on 1 bar at peak revs...
  7. #262
    Jun 2007
    Dunedin
    aye man,
    Hows that blitz bags powered girl of yours going, got your manual in there now?
    You can see on the dyno sheet there below that it does drop quite a bit, but everything seems to be fine and its pulling sweet though.
    Imagine what it could do with the boost at 13-14psi sustained?
  8. #263
    Awesome result for that boost level Man ! Thats wicked.
    If your DYno opperator is willing you can always disconnect the vacuum lines to the wastegate actuators, block the vacuum leak with rubber block offs and see what the turbos are actually capable of holding.
    I know my stock twins will hold the 14psi mark in a crude fashion.
    You can see my boost curve here:
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  9. #264
    Jun 2007
    Dunedin
    Aye hows things mate,
    Ive been real busy lately but that sounds like another good idea to do, and thanks i think its pritty good those figures too.
    I would like the boost to be at least a bit better lol.
    also remember people that mine is....
    GA70 mk3 Supra 1986,
    ENGINE:
    * Polished stainless steel 2.5 inch intake piping
    * Polished 1 litre alloy catch can
    * Simota crankcase breather filter
    * New gaskets and water pump
    * New thermostat coolant and hoses clips etc
    * Air conditioning system removed
    * Ngk Iridium tip performance spark plugs
    * New Eagle 8mm performance coil lead and all other ignition leads resistance tested
    * Fuel injectors pressure and flow tested with new seals and replaced inlet manifold and tvis gaskets, new manifold bolts fitted
    * New distributor cap and points checked and cleaned
    * New Trd oil filter and Castrol magnetec oil
    * Trd radiator pressure cap
    * Boost gauge with chrome pod cover
    * Full 3 inch mandrel bent exhaust with Apexi stainless steel muffler
    * K&N Monster Pod filter
    * Gen3 counterweight balanced crankshaft and replacement pulley, new gates timing belt, new tensioners idler bearing and springs etc
    * Heat proof painted turbo heat covers
    * Powder coated tappet covers and battery cover, boost control box
    * Reconditioned factory Gen2 Ct12 twinturbos (Done approx 20,000kms) with braided water hose lines
    * 3 inch front mounted intercooler with 2.5 inch stainless steel powder coated pipework, and 2.5 silicone reducer hoses
    * Heat wrapped exhaust and pipework
    * Electronic boost controller fitted with custom mounting bracket and dyno tuned to run 14-15psi
    * Reconditioned Engine, light port and polish head, performance head studs, chrome moly rings, torqued head to 50ftlbs, polished crankshaft
    Shaved 10 thou of pistons compression ratio down to 8.4.1 All bearings gaskets and seals done.
    * Silicone blue vacuum hose, boost controller and boost gauge lines
    * Bosch loop/charge by-pass valve setup
    * Twin 12 inch electric fans with thermo switch
    DRIVELINE:
    Lightened factory flywheel
    Up-rated factory 2600lb pressure plate
    Xtreme 4 puck brass button type ceramic clutch disc
    W58 toyota 5 speed gearbox
    3:9 ratio 8 inch lsd
    SUSPENSION/BRAKES:
    Disabled factory tems
    Tein 35mm lowering springs
    Kyb gas shocks shortend 15mm (front)
    Monroe gas shocks shortend 30mm (rear)
    Nolethane Bushes sway bar (front)
    Toyota Replacement Bushes swar bar (rear)
    Bendix brake pads
    WHEELS/TYRES:
    Tsw 17/8 inch mag wheels
    Hankook Ventus 225 tyres (front)
    Hankook Ventus 245 tyres (rear)
    EXTERIOR:
    Facelift front bumper
    Facelift rear lights
    Facelift rear spoiler
    De-badged body
    Jet black high gloss respray alround
    Supra decals
    INTERIOR:
    30 percent window tints
    Boost gauge
    Custom leather hand brake cover
    Momo steering wheel
    Aftermarket boss kit
    Solid mounted fire extinglisher
    Shorter t series gear shifter
    ICE:
    Sony 45/45 watt CD headunit
    Sony 6x9 speakers in carpeted custom box
    Infinity 6 inch speakers with custom boxes
    Kenwood 4 inch door speakers
    PERFORMANCE:
    280bhp @ flywheel @ 14.0 Psi
    thats a good runup about her
  10. #265
    Jun 2007
    Dunedin
    checked over a few things now on it and have come to a conclusion, that it will most likely be the gen2 twins actuators creeping a little bit leaking some boost up revs, as there not as efficient as the gen3 ones. As well as the inconsistant controller setup. The gearing is far to long for them as well with 220kms in 4th gear putting some strain on them too.
    Next plan of attack is to fit a shorter geared diff like 4.5 or 4.6 ratio better boost controller and go from there.
  11. #266
    Aug 2009
    --Delete--
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
  12. #267
    GTTwin, why are you running the gen2's? I though GA70's came with Gen3's?
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  13. #268
    Jun 2007
    Dunedin
    Quote Originally Posted by timbosaurus View Post
    GTTwin, why are you running the gen2's? I thought GA70's came with Gen3's?
    Yes the later GA70 does come with gen3, but mine is a 1986 Gen2 model all modified like the newer ones except not widebody, still has the Gen2 auto factory ecu in it too. I got the turbos for $350 so i went with them even though they are gen2 because of the good price.
    Nov 2007
    Like mentioned earlier, does anybody know if the factory AFM is a restriction with the stock turbos, or blitz bags at high boost levels?
    The opening in the AFM is pretty small.
  15. #270
    No, the factory turbos will run out of puff before the AFM becomes a restriction.
  1. *** Dyno Day History Lesson ***
    Last Post: 09-04-2013, 09:50 AM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 01:32 PM
  3. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 11:46 PM
  4. std altezza 3sge on chassis dyno
    By Celica RA45 in forum Tech and Conversions
    Last Post: 29-12-2005, 01:06 AM
