Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 150
Thread: Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
  1. #46
    New Zealand
    Default Re: Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Jsut measured my rt40 diff.
    4x114.3
    hub face to hub face 1335.
    got manuals and can provide further details if required.
  2. #47
    User Conversion King
    NWA
    great,
    recent info added
    brett
    hello
  3. #48
    Hey what happened to the RT132?
  4. #49
    NWA
    meh,
    all those codes i put in off the top of my head. thought there would be some missing.
    is it BW??
    hello
  5. #50
    yep, bw, 3.9:1 xt130/rt132, maybe smae diff for other toyotas
  6. #51
    Offline Grease Monkey Toycrash's Avatar
    Finland
    KE20L -74 Euro spec rear axle code: B092 saying 145mm(on service spec catalog says 6.25" tho..?) (not U-series 6") 4.222 ratio with open center.
    On KE26 ratio is 4.444 all ke20 series 2-pinions
    referring to master catalog allso 4.3 and 4.555 have been available.
    The U series might been pre -74 ones. KE series chassis book dated to -74 says axle is 6" so mine -74 is downrated version (or wtf?)
    KE30R KE35R and KE36R 6" and 4.300 and 4.556 ratios 2-pinions
    TE3# series 6.38" 4.100 and 4.300 ratios 4-pinions
    TE37L and TE47R 6.7" 4.300 ratio 2-pinions
    TE
    On KE70 euro spec axle is NOT borg warner.
    TE71 Axle is S-series 4-pinions(allso 2-pinion version found)
    TE71 GT 2T-G engined axle is T-series(same as T18?)
    Old toys for old boys
  7. #52
    G'Day mate, here is some info from a Jap Spec RA35 GT
    Rudi
  8. #53
    NWA
    Quote Originally Posted by 7M-GTE MX73
    Rudi
    hi,
    thanks for the info. changes have been made. curious as to whether your setup is drum or disc??
    brett
    hello
  9. #54
    G'Day Brett,
    i wish it was mine, but its actually my aunties car...
    it runs drum rear brakes
    Rudi
    hi,
    brett
  10. #55
    Tasmania
    As to info on XT-130 And RT-132 diff codes,the XT-130 runs the plastic Borg Warner diff and the RT-132 possibly runs either E series or T as this is a Jap import vehicle.If unsure there should be plenty ppl out there that owns a Liftback Corona and can check their ID plate.As to the MS55 and MS65 Crowns they both run a Holden rear end identical centre to most banjo holden rears.They never ever had Borg Warner diffs in them,Actually no Crown ever ran a Borg Warner diff from the factory unless someone has done a conversion.
    Cheers Brett.
  11. #56
    Junior Member Backyard Mechanic manny's Avatar
    Some 90s Soarer and Supra A series (200mm) diff info for the collection....
    Z30 Soarer Diff (all A series) ratios by model/trans
    V8
    UZZ30 3.916:1
    UZZ31 3.916:1
    UZZ32 3.916:1
    3L I6
    JZZ31 4.083:1
    2.5L I6 TT and VVTi
    JZZ30 MTM 4.083:1
    JZZ30 ATM 4.083:1
    Axle Codes
    A01A - 3.916 ratio Open Centre
    A01B - 3.916 ratio Torsen LSD
    A02A - 4.083 ratio Open Centre
    A02B - 4.083 ratio Torsen LSD
    JZA80 JDM Supra A series diff ratios
    4.083:1
    3.769:1
    3.266:1
    Ratio - Crown/Pinion teeth count
    4.083:1 49/12
    3.917:1 47/12
    3.769:1 49/13
    3.266:1 49/15
    GSE20 IS250 - daily
  12. #57
    Junior Member Grease Monkey MacroP's Avatar
    MX83 Cresida diff codes are G312 for GLX models and G315 for Grande models. Verified as I have both.
    Hope this helps.
    Also for a bit of trivia
    Landcruisers now run a B series diff on the rear(LSD too) and A series reverse gear hilux front end. Ratios can 3.9, 4.1 or 4.3:1 depending on engine and trans. The newer B series diffs seem to be weaker than the older K series(9.5inch) diff as you would expect. Smaller diff means smaller crown and pinion teeth size. Common failure on our minesite now.
    Hiluxes now run A series on the rear (LSD in 4x4 only) but am not sure if they still run the smaller diff on the now standard IFS. Ratios can 3.5, 3.7 and 4.1 depending on config possibly more.
    I should have a good look at the vehicles(and the newer code style) at work because we have nearly every version of diesel Hilux and Cruiser made in the last 15 years running around.
  13. #58
    Victoria, Mt Macedon
    Quote Originally Posted by crowncustom
    ... and the RT-132 possibly runs either E series or T as this is a Jap import vehicle...
    RT132s definitely run a T series rear end. They should be the same width as a T18 T-series because the axles are 100% identical. They have drums too.
    Hen
  14. #59
    Sheebz Automotive Grease Monkey Gleno28's Avatar
    Hey, great resource!
    I've got a '82 KE70 pannel van, which i'm fairly sure were all imported by toyota, model code is KE70-RG and it is running an S312 diff standard. (which was a pain sorting the tailshaft with 4age conversion!) Haven't got a width yet but it's drum, same stud pattern as AUS KE70.
    Glen.
  15. #60
    Glen.
    do you know the diff ratio in those things?
    are they the jap bango or the borg warner?
    more for my own curiosity but its all helpful
