Page 10 of 10 FirstFirst ... 8910
Results 136 to 150 of 150
Thread: Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
  1. #136
    Junior Member Grease Monkey Rob KE25's Avatar
    Default Re: Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Just found a MX62 with a E302 diff code. diff E series (7.1inch) 3.7ish ratio.
    Is it me, or others also that can't open the links on the first page for the collated data?
    Daily Driver: KE25 with 3sge, W58, Coilovers, Rack and Pinion, LSD, Roll cage etc. Getting to work is lots of fun! KE25 link: http://www.rollaclub.com/board/index...howtopic=11909
  2. #137
    sel
    I cannt open it neither... @@
    ouT of oRder!!!
    CUBE needED!!!
  3. #138
    Quote Originally Posted by ecko View Post
    can anyone confirm a diff that is interchangable with st141 BW?
    i was hoping ra60 might but it doesnt seem to according to the charts
    XT130 will fit. I bought a 8 inch diff from Chris Davey and it was in his XT130 and it fitted into the rear of my RT142.
    RT142 and ST141 have the same rear end in live axle.
  4. #139
    Old Fart Backyard Mechanic dale30's Avatar
    Casino nsw
    Quote Originally Posted by crownv8 View Post
    The Aussie build MS55 and MS65 had Holden diffs, not Borg Warner. Holden actually built them for AMI under contract. They were a 3.9 ratio course spine diff and still had "Holden" stamped into various parts. Basically the same assembly as HT Holden except for ratio. Any Holden banjo centre will fit as long as you use course spline star gears. These are the models that have the much sort after front hubs for the Supra five stud conversion.
    Never seen a Crown with a Borg Warner diff??
    BTW AMI stands for Australian Motor Industry they assembled some Crowns, Coronas and Corollas. They even assembled Rover vehicles.
    They pretty much took a good car and ruined it "for Australian conditions".
    Shane.
    Also assembled ramblers as well.
    XT130 speedway car XT130 road car
    2 x Renault Fuego speedway cars
    02 TS50 falcon
    Light travels faster than sound. This is why some people appear bright until you hear them speak
  5. #140
    Mar 2009
    Auckland
    hey does anyone have a copy of the link as it doesnt work anymore. also altezza diff heads fit in f series diff does that mean that a soarer and similar will to and they are a series as well? from what i have read they will need modified axles to fit?
  6. #141
    Quote Originally Posted by mr75 View Post
    Better to use Norbie's one now I think.
    http://akb.norbie.net/Public/AxleSearch.aspx
    ([][][]II--LT--II[][][])
  7. #142
    You would be better searching for a thread in here about later model diffs - basically not all so-called "A" series diffs are the same or even compatible!
  8. #143
    Act
    Just checked out Norbies pages
    MS5X and MS6X are coil except for the MS57's and not sure if any MS6X was leaf as to my knowledge there is no ute or load povo spec wagon
  9. #144
    Act
    Has anyone got any track info
    I've got the G under the wagon and the engineer wants me to stay within the 25mm track increase rules, of the donor car
    so far I have found that the track on a RN 30, 40 and 60 series 4wd is 1400mm @ rear and a RN80 series is 1370
    however what track/offset wheels did a RN20 run fom factory??? as this is the diff I've got under the car
    According to the numbers I've got and the table a RN 80 should run +20 off set wheels can anyone confirm. As I need to find a lux of g series that runs -10 wheels from factory so I can run my -22 offset
  10. #145
    nuts Grease Monkey
    auckland
    is it ok to point out errors in norbies diff info page?
    like ae95 with 4x114.3 and 1325 width??
    ma45/46 with integrated drum handbrake... should that say integrated caliper handbrake?
    "Comments: ADM version. The S diff can be identified by 1 long stud at the bottom."
    That long stud is not to do with diff size.. but rather to suit the ratio inside. taller ratio usually has a long stud at the lower right to clear the larger pinion gear. some even two long studs like the kp61 3.3:1 U-series head. This info on the diff page may be suitable if the ADM S diff in ae86 were all the same ratio.. but confusing otherwise.
    why double up on RT132?
    ok i stop now
    -Mark
    E2 + E7 fan
  11. #146
    Jul 2012
    vic
    anyone know what centres will go into an mx32/
    the standard ratio is crap for highway cruising.
    i believe its 3.9 so i need something like 3.5 or better.
    5M MX32 Cressida 1980 - Stock as a rock!
  12. #147
    Act
    has if got a data plate?
  13. #148
    Jul 2012
    vic
    no but this site says;
    http://akb.norbie.net/Public/Chassis...1&ChassisID=33
    E312 7.1" 3.90:1 2-pinion open
    edit; just looked at all the diff options on that site, only ratio that is taller is 3.7 which isn't much of a difference. this is an mx63 which has an 3.72 ratio.
    only option in toyota e series on that site...
  14. #149
    Jun 2014
    Sjaelland
    If I want to swap the ratio of my rear end on my 1970 MS55 that has a 4 speed - what year rear end from a HiLux should I be looking for to make a swap? I've thought abort swappping the gearbox for a W58 but thought that swappping the rear end cold be a simpler job.
    I've tried to find the the topoc in the thread but without any luck.
    Maybe there is even a guide somewhere in here?
    Anhænger helt and advice appreciated.
  15. #150
    If you go for a MS112 diff you get rear discs, internal drum handbrake, bolts straight in, just need to shorten(I think) the panhard (cut, get some solid bar for up the centre, cross drill and plug weld the solid in it and rejoin) and still same diff series.
    Friends
