Page 2 of 10 FirstFirst 1234 ... LastLast
Results 16 to 30 of 150
Thread: Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Default Re: Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Quote Originally Posted by ae86drift
    the AE95 are the same splined axels as the kouki (ie tough as guts) AE86 but the spline length makes them unusable
    I'm going to refute the above statement - There is no such thing as a "tough as guts" T series diff or axle.
    Compare the kouki(??) T series axles to that of an F series or G series - you will see
    Also, its not the spline length which makes them less usable, its the fact that they are 4x100 not 4x114.3
    AE86 Tuning Life Backyard Mechanic Garth AE86's Avatar
    Sydney NSW
    hahah very funny karl
    its the toughest t series there is though.
    and takai point taken.
    is there no way to change it?
    Garth - 100% AE86 Addict
    AE86 - Levin & Trueno - The Legends Live On!
    'AE86' - Toyota Sprinter Trueno GTV
    "It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
    Toymods Club Member Backyard Mechanic Big T's Avatar
    Sorry dudes! I mixed up the rare/common ratio bit. Will edit my post to correct it.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    The Aussie build MS55 and MS65 had Holden diffs, not Borg Warner. Holden actually built them for AMI under contract. They were a 3.9 ratio course spine diff and still had "Holden" stamped into various parts. Basically the same assembly as HT Holden except for ratio. Any Holden banjo centre will fit as long as you use course spline star gears. These are the models that have the much sort after front hubs for the Supra five stud conversion.
    Never seen a Crown with a Borg Warner diff??
    BTW AMI stands for Australian Motor Industry they assembled some Crowns, Coronas and Corollas. They even assembled Rover vehicles.
    They pretty much took a good car and ruined it "for Australian conditions".
    Shane.
    User Conversion King
    NWA
    Quote Originally Posted by river
    Looks good, but isn't your "ratios" column incorrectly labelled. This looks to be part of the diff code and not the ratio. For example, the RA25 GT diff code is "5F2-F313", which (IIRC) makes it a 7.5inch 2-pinion LSD with a ratio of 3.909. Also, the RA25 GT has drum brakes on the rear.
    seeyuzz
    river
    i put the ratios in the toyota form and plan to paste this into the file;
    Read the Axle Code from the vehicle indentification plate.
    first digit: ring gear diameter
    A 138mm
    B 145mm
    C 6.25"
    D 6.62"
    E 7.1"
    F 7.5"
    G 8"
    H 9"
    J 9.25"
    K 9.5"
    L 10.5"
    M 12.5"
    N 13.5"
    P 14"
    Q 12"
    R 162mm
    S 6.38"
    T 6.7"
    U 6"
    V 10.6"
    W 15.5"
    X 142mm
    Y 158mm
    Z 202mm
    - no ring gear = FWD
    Second, third digits: gear ratio
    01 3.30
    02 3.36
    03 3.545
    04 3.556
    05 3.70
    06 3.889
    07 3.90
    08 4.111
    09 4.222
    10 4.375
    11 4.444
    12 4.625
    13 4.79
    14 4.875
    15 5.125
    16 5.286
    17 5.60
    18 5.714
    19 5.833
    20 6.167
    21 6.667
    22 6.78
    23 6.833
    24 7.64
    25 4.556
    26 5.571
    27 3.364
    28 4.30
    29 4.10
    30 3.727
    31 3.909
    32 6.591 or 4.807
    33 7.503 or 5.583
    34 6.781 or 4.786
    35 7.636 or 5.60
    36 4.778
    37 3.583
    38 3.417
    39 3.154
    40 5.375
    41 3.308
    42 6.500
    43 3.550
    44 3.214
    45 3.533
    46 2.928
    47 3.944
    48 3.356
    49 3.729
    50 3.400
    51 3.736
    52 3.722
    53 3.250
    54 3.941
    55 3.333
    56 2.821
    57 4.058
    58 3.238
    59 3.234
    60 3.519
    61 2.724
    62 2.892
    63 2.655
    64 4.312
    65 3.837
    66 3.071
    67 3.526
    68 3.095
    69 4.176
    70 5.857
    71 2.962
    72 3.949
    73 4.285
    Fourth digit: no of pinions, ltd slip-yes/no
    Code pinions ls
    2 2 no
    3 2 yes
    4 4 no
    5 4 yes
    hello
    NWA
    Quote Originally Posted by gianttomato
    MA45 - T series. MA46/7 - F series
    MX10, MX12 were E series. MX22 auto is E312.
    MS65 had Borg Warner diffs. AMI built MS55s had Borg Warners too.
    Pretty sure most/all those early Corollas (KE1x, KE2x) have U series diffs in them. After that they had Borg Warners or U series depending on whether they were made in Japan or AMI.
    RT81 had a Borg Warner or S series diff depending on whether they were made here or in Japan.
    done..........
    89 Tarago with the F282 is a YR22.
    Hen
    yeh i found your post in the "f series diff ratio availability" thread. thats were that came from
    changes made there also....
    hello
    <1973 TA22 manual had 4.1:1, D series 6.67" rear end
    >=1973 TA22 manual had 4.1:1, T series 6.7" rear end
    4.3:1 T differential was available in TA23 auto as an option only.
    Every australian TE72 liftback (T-18) I've seen is 3.9:1.
    Sydney NSW
    theres the answer i wanted
    cheers mate (+rep 4 u)
    NWA
    Quote Originally Posted by SeptemberSquall
    changes made
    hello
    Junior Member Backyard Mechanic MOOKIE's Avatar
    tas
    if u can break a T series with 67 fly wheel kw then i wouldn't call them strong at all !
    Props for putting this info together mate ur gunna help out alot of ppl !
    Penrith BC
    that a and b series stuff is incorrect
    a series is 200mm crown wheel, b series is 220mm
    im not sure how those numbers got so popular, or what they actually refer to!!
    ../delete/ban
    tech moderator
    the ratio / sizing info brettles here has been referring to is the chart available from the Toysport website.
    Unfortunately this information doesnt hold for the "new style" gearbox / diff codes that Toyota has been using since the early 90's.... this includes the A series diffs now used in the Hilux and Supra.
    Basically - if it's 1990 or newer, disregard the chart above
    Now, some use[less] info from Teh Witzl!
    # RN2* Hilux = 1370mm width, will measure drum size tonight
    # RN4*/YN4* Hilux = 1410mm width, unsure of drum size (i think 8"?)
    # UZS131 Crown = G series, IRS, G474 code iirc, non-LSD
    # AE71/KE70 = ghey bog warmer, 1410mm width, p00
    # TE72 (aka T18) = T sereies, 3.9:1 ratio, open centre, 1410mm width
    *****NOTE: AE71/KE70 driveline is BOLT IN replaceable with TE72 T-series gear (you need TE72 gbox, tailshaft and diff)
    NWA
    can anyone tell me the presise width of the MS112 diff.
    so far ive read of 3 different disk-to-disk widths
    need to know if width will come close to the RA40 width.
    hello
    NWA
    # RN2* Hilux = 1370mm width, will measure drum size tonight DONE
    # RN4*/YN4* Hilux = 1410mm width, unsure of drum size (i think 8"?) DONE
    # UZS131 Crown = G series, IRS, G474 code iirc, non-LSD DONE
    # AE71/KE70 = ghey bog warmer, 1410mm width, p00 DONE
    # TE72 (aka T18) = T sereies, 3.9:1 ratio, open centre, 1410mm width DONE
    *****NOTE: AE71/KE70 driveline is BOLT IN replaceable with TE72 T-series gear (you need TE72 gbox, tailshaft and diff) DONE
    hello
