From some hulks today
Crown F292 7.5 4.100 2 open
Celica RA40 T292 6.7 4.100 2 open.
Cresida E302 3.727 2 open
T18 had a 3.727 also T diff
i think it's only the earliest model, but my mx22 ratio is E072
beer me!
1968 RT40S Corona 1600S series II (restore in progress)
1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
2012 ZN-6 86GT (shed find 5000 km in 6 years)
Just measured the width of my live axle Borg Warner RT142 Corona Avante. I got 1430mm measured from the mounting face of the disc. Looks like she will cop a G series![]()
lite aces are E code and as much as ive seen 282.
jap 86s are t282/283 ( lsd less common than is widely thought) same ratio autos and manuals.
Originally Posted by SillyCarS
Originally Posted by Norbie
Not exactly true, due to different bearing sizes, you cannot directly swap a 4-pinion carrier into a 2-pinion G series solid rear housing, not to mention the gear set issues. The 4-pinion G series LSD carriers from an IRS are a direct swap ONLY if you have the 87 and later reinforced solid rear diff (4-pinion). In general, this diff was used on 22RTE and V6 4WD models, but there are always exceptions...
The middle carrier in this picture is the 4-pinion reinforced carrier, the one on the left is the 2-pinion solid rear G series carrier
http://home.4x4wire.com/erik/diffs/3rds.jpg
That said, Precision Gear makes a master installation kit that includes bearings that will allow you to install a 4-pinion carrier into a 2-pinion housing and also use 2-pinion gear sets... but that's not really a good idea. Your money would be better spent finding a 4-pinion housing
Originally Posted by wraith
Yeah well Toyota served the masses didn't they 3.909 like assholes everyone had one.
Not so bad in traffic pretty OK on the 60 mph speed limits of the day.
3.727 in the TE series was the other standard.
Non standard are the 4.100 & more so the 4.111 (GT's).
Why 4.111 fast off mark and high top speed.
Good overtaking in 3rd to 7000 rpm 150 kph
4th to 7000 rpm 190 kph.
T/S in 5th at 6800 rpm (zero % efficiency a.k.a. FLAT OUT) 220+ on an 18rg with 4.111 and 14 inch wheels.
Wagons and utes 4.375.
Rest unsure.
Nissan nused lots of 3.700 but not so Toyota for some reason.
not even steven,Originally Posted by RT104GT
all (read nearly all) the aus delivered TA22s, RA23's, RA28's, RA40's and even MA61's a 4.1:1
i also sigted a 92' model 2wd hilux the other day that are G292 (4.1)
hello
Whats the go with E series differentials? I poked my head under a few taragos at a wrecker and the centre casings look pretty big on them and some had reasonable ratios too and discs I think.
Has anyone ever used them in a performance application?
Im not allowed to advertise in my sig, so see the classifieds.
Mazda 1300... Rotary powered because no one would make me some 4AGE engine mounts!
Very difficult to find aftermarket centres for them and there weren't many OEM E-series LSD's (I've never seen one), so they kinda suck for performance applications unless you're happy to weld it up or leave it as a single-spinner.
F series is a much better option if you want access to aftermarket goodies.
Norbie!
www.norbie.net
ahhh gotcha.
was just thinking aloud, cheers for that.
next question:
what sort of differential is in a Toyota 60 series Landcruiser.
My question is because, would this: http://cgi.ebay.com.au/Toyota-60-ser...QQcmdZViewItem
fit into my shortened Hiace Van diff (assuming G series).
No, Cruisers use some monster diff which is way bigger than the G series. It's 9 3/4" or something crazy like that.
Norbie!
www.norbie.net
bum. Cheers for that.
Brett,
Good work so far on the diff doc.
Is there an update coming soon?
Norbie,
Your the 2 links on http://www.norbie.net/ToyotaAxle/
don't work (just gives an eror page).
Do I need a password?
I've been adding more stuff to my own site.
As you've already seen, I've tried to list the diff for each model.
I've also been making a list of crown and pinion part numbers.
Feel free to copy what you want.
http://ourworld.compuserve.com/homep...tepho/diff.htm
I'm only halfway through typing in the info I've got but I've already covered most of the cars we actually care about (only just started on JDM Corolla, to be followed by Corona).
Australian cars assembled by AMI often have Borg Warner diffs that start with the code AM (eg AM70).
Mitch asked Borg Warner if we can still buy an LSD for these and they said the LSD's are well and truly out of production.
There is a story in "The Long Run" (history of Toyota in Australia) about how the Holden diff found its way underneath the AMI assembled MS65.
I will dig it out and post it when I find it.
One thing to be aware of, it was mostly (but not only) GT models that had LSD. but even there it was only optional.
For some countries like the UK, the RWD Celica always had LSD on the GT models, while for other countries it was a rarely used option.
A *general* rule is that an 18R-G/GE/GEU/GU engine will usually have an F series LSD (eg RT104 Corona, RA2#/3#/4# Celica).
Somebody asked if the RA35 has discs.
No Celica A2#/3# ever had rear discs.
That had to wait until the 4#.
Another useful little rule I've found is that a Celica/Supra/Carina 4# always has solid axles, while a Celica/Supra/Carina 5# has IRS.
- Stepho
Yeah the URL has changed:Originally Posted by stepho
http://ToyotaAxle.norbie.net/
Norbie!
www.norbie.net
