Page 3 of 10 FirstFirst 12345 ... LastLast
Results 31 to 45 of 150
Thread: Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Victoria, Mt Macedon
    Default Re: Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    can anyone tell me the presise width of the MS112 diff.
    MS112 is 1450mm disc to disc. 100%, just measured it then.
    Hen
    User Conversion King
    NWA
    Hen
    its great that you measured it , not so great about how wide it is
    might be able to correct it with appropriate wheels though
    hello
    the idea is to have 1 table that can be refered back to later to find anything toyota diff related.
    I think this is a great idea, but wouldn't it be so much better to have an online database which can be dynamically altered instead of a static document which you have to manually update?
    The answer is yes, which is why I created this:
    http://www.norbie.net/ToyotaAxle/
    Now if I can just figure out how to set up ODBC connections on my web host it will be sweet. Works great on my PC though.
    Junior Member Grease Monkey smitty1's Avatar
    Ke1X and KE2X stud pattern is 4 x 110. Ke3X is 4 x 114.3.
    Cheers, Ian
    NWA
    yeh thats all well and good if your bill gates and can do anything with a computer ....i work with what i got and what i know
    stuff regarding the corolla PCD's is added too
    hello
    NWA
    UPDATED
    hello
    malaysia
    This is JDM spec RA45 GT..without LSD..
    1976-RA28 Cicely mosquito LB2000GT
  8. #38
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    Some AE86 stuff:
    late model Levin's all had 4.3:1 ratio diff, manual and auto (and I expect all JDM AE86).
    AE85 have 3.727:1 for manual, 3.909:1 for auto
    ADM AE86 has S series 3.909:1 (all are manual)
  9. #39
    Not quite all Rochester. Early JDM AE86 Autos had a 4.1:1
  10. #40
    Hey i have heard off many people that an ma61 Lsd will go straight into a irs rt142. Does anyone if this is true or has anyone done the conversion?
  11. #41
    NWA
    Quote Originally Posted by Mattrt142
    yep that will work. both the said diffs are F series.
    hello
  12. #42
    New Zealand
    Quote Originally Posted by gianttomato
    Pretty sure most/all those early Corollas (KE1x, KE2x) have U series diffs in them. After that they had Borg Warners or U series depending on whether they were made in Japan or AMI.
    KE1x and I think early KE2x (oldcorollas will be able to confirm) actually used a B code diff. With the right parts though they can be converted to U code in the B code housing, same way the KP6x X code can be converted to U code. LSD centre from X code and B code interchange.
    Callum
  13. #43
    NWA
    yep, i think ill let the expert (oldcorollas) make everything clear.
    are you commenting from a new zealand side of things? i have no idea whether there is a difference at all
    hello
  14. #44
    New Zealand
    Pretty sure KE1x and KE2x are the same for NZ and Oz. We never got Borg Warners in the KE3x's though, everything should be similar spec to Japan although locally assembled.
    Callum
  15. #45
    ke70's had a 3.889 in manuals
    except 5 speed sedans which run a 4.300 or an optional 3.889
    and the autos run a 4.111
    hope that helps
