im currently in the process of building an AE82 corolla sedan and have recently aquired a 4agze engine minus a supercharger and i am rebuilding the block with the hope of putting a 4ag carby head on it. first question is weather or not this is possible?second question is if it will work, will the extractors off the gze head fit the ge head? any help is appreciated. as the sooner i get this car back on the road the sooner i can start the
4age 20v conversion on my AE86 levin.![]()
Hi Luke,
I wondered when I would see you post on here!
Found this link while trawling around, might be of use:
http://www.toymods.org.au/forums/arc...p/t-26718.html
Also this link is usefull to find out the potential/benefits of different engines:
http://www.sssautomotive.com.au/Engines/toyota.htm
The biggest problem I can see mate is the fact that the Z motor has lower compression, to componsate for the boost of the super charger. Without the charger you wont be going anywhere fast, but the intenrals are stronger in the Z motor.
I reckon you should just get a SC14 Supercharger, and set it up in a suck through carbied set up, or blow through if you can be bothered pressuring your carby. If you want to go this way let me know, I have been doing heaps of research for the turbo 'Rona project.
Kind Regards,
Ryan
Hmm. This is puzzling and of slight concern. I was talking to the owner of a local workshop that specialise in cylinder heads and he said the 4ag (not 4age) did not come with holes for fuel injectors and that it was a carb head similar to a 4af but not the same. So i am unsure what the go is there? I asked for a smallport.
And i am aware of the underlying issue of low comp pistons hence the rebuild so there should be no drama.
Just a thought, would the extractors in question fit a 4afe/4af head?
www.billzilla.org
Toymods founding member #3
lol oh fck i just read its an ae86 and that its a 20v head?. all 4agze's were FWD, the extractors will not work on a RWD car.
4agze extractors are 16V, so wont bolt up, regardless neither will work on a rwd conversion.
RE: 4af:
4ag(z)e extractors do not fit on 4afe's 4afc's or 4ac heads.
It's an AE82 sedan...
The best 'stock' extractors you can get are the blacktop extractors, but you'll need the secondary pipe too.
They will fit a 16v head with the addition of two holes in the flange.
Hiro is spot on the money
I did heaps of research befor buying my smallport
The bigport has smaller crank,rods and is only 3 rib
The smallport is 95% the same as the GZE with just the pistons different !!!
Smallport injectors are in the head !! if thats any help
If you need any Pic's of a 4age smallport just sing out and ill post anything i can![]()
Ae90 Hatch 4AGTE Small port http://www.toymods.org.au/forums/showthread.php?t=64566
Same car More info http://www.toymods.org.au/forums/showthread.php?t=63892
LAUGH NOW CRY LATER ! Cars and Girls will do that to you !!!
