Results 46 to 54 of 54
Thread: 4agze extractors on a 4ag head?
  1. #46
    Sep 2009
    Default Re: 4agze extractors on a 4ag head?
    Are you sure?
    i know the comp droppers are 1.2mm and the ones that bump up your CR are .8mm and im pretty sure 0.040" is a replacement size which is.. oh fuck i was wrong 1.02mm but seriosly i thought that, i have no evidence but.
    is there an online 4age book hosted on toymods or something?
  2. #47
    Aug 2009
    Quote Originally Posted by Casey-G View Post
    Sorry i meant 7afe, but yes apparently the headgasket is .8mm from the factory which is thinner than a 16v 4age HG from factory (1mm) but have the same oil/water/bore and bolt holes aka are a match, therfore is you own say a ae92 sx/gti with a 4age, you can bump the compression up on the cheap by buying a factory replacement 7afe HG instead of a "cometic/TRD ect" .8mm head gasket.
    I'd like to meet the guy, cant believe everything you hear till its from the mouth (no offence) i know 300kW is easily doable on a stock bottom end with a 4age.. maybe he underated the toyo factory gear by mistake
    seen a dyno sheet from a guy over in NZ with a 4agte hatch, pushing 32psi though stock gze internals with a blacktop head making in excess of 350kW at the front treads so its deffs doable.
    He blamed the tuner for blowing the block. They had a difference of opinion on fine tuning.. as he was the mechanic/drift racer & not the expert, he trusted the tuner against his own better judgemnet & BAMMO! ...lived to regret it..
    Got any links to 300+kw 4A's?
    PS. I'd love your ghey seca even more if it was converted to AWD or RWD.
    Power at the front treads always makes me smile & shake my head ...somehow it just aint right LOL
  3. #48
    Jul 2007
    Are you sure?
    yeah pretty sure its here somewhere. i have it on file anyways, doesnt say anything about HG thickness in there.
  4. #49
    Administrator Backyard Mechanic
    Jul 2009
    Standard headgaskets are more than adequate... As the guys have said something else is busted and it isn't the headgaskets fault.
    I've always had the opinion it is far better to blow a headgasket than destroy a head / block.
  5. #50
    Aug 2009
    Quote Originally Posted by Gavatron View Post
    Sounds like he's going from 8.0:1 early GZE pistons to the 8.9:1 GZE pistons, which will definitely change his compression ratio....
    ..Is it true that turbo d & supercharged engines should run lower compression ratios?
    I'm running a sc14 so is there any danger or anything I need to know about, running the 8.9:1 CR & sc14?
  6. #51
    Sep 2009
    nah its pretty right, you only lower the compression on a turbocharged engine to get the turbo into its efficiency range at "x" amount of revs ect..
  7. #52
    Chiba
    And to prevent detonation on anything less than race fuel when at decent boost.
  8. #53
    Sep 2009
    in which.. 14-17psi with the sc14 is really childs play in terms of what they can handle with supporting internals/fueling
  9. #54
    Aug 2009
    Cool guys Thanks
    Good to know...
  1. 4agze head gasket size?
    By johan_oern in forum Tech and Conversions
    Last Post: 25-09-2009, 04:29 AM
  2. 4AG head bolts - crack crack
    By Grega in forum Tech and Conversions
    Last Post: 28-02-2008, 07:54 AM
  3. 4AGZE Piston and 20V Head Volume
    By Bazooka in forum Tech and Conversions
    Last Post: 20-10-2007, 05:30 AM
  4. Fitting BT 20V head to 4AGZE Block
    By KOV51 in forum Tech and Conversions
    Last Post: 07-09-2007, 05:21 PM
