Results 31 to 45 of 54
Thread: 4agze extractors on a 4ag head?
    Aug 2009
    Default Re: 4agze extractors on a 4ag head?
    Quote Originally Posted by Hiro View Post
    Only true of the early bigport 4AGEs. The later bigports (and the bigport 4AGZEs I believe) are 7-rib and same size crank/pin as the smallport.
    Sorry to OP - for being a bit off topic..
    Yes Hiro,
    You are right. I own a 1st gen AFM bigport 4AGZE from a JDM AE92 Levin & it's got 7 ribs but no ceramic pistons & no oil squirters.
    Because of this I recently bought a smallport bottom end which I plan to put the big port head on.
    What will this do to my compression ratios? - I'll be using the cometic steel racing head gasket.
    Being a noob' I don't know about comp ratios & what the numbers mean exactly, so if you can tell me whether it means more top end or bottom end power, that might be helpful
    May 2010
    TAS
    Wont affect the C/R, the deck height of the two blocks are the same.
    In simple terms C/R is the how much the piston will "squish" the air fuel mixture at the top of the compression stroke.
    For instance 9:1 comp ratio is the air fuel mixture compressed 9 times its original volume in the cylinder at the top of the compression stroke.
    Higher C/R = more squish, which = more bang. It is limited however by a number of things, fuel octane being one.
    Basically N/A cars run a higher C/R and forced induction ones a lower C/R as forced induction fills the cylinders past 100% volumetric efficiency anyway.
    I'm sure Hiro can explain further.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Sounds like he's going from 8.0:1 early GZE pistons to the 8.9:1 GZE pistons, which will definitely change his compression ratio. It's not just about deck height.
    May 2010
    TAS
    True, I was thinking he was only changing the block itself and retaining the same internals for some reason
    Aug 2009
    No.. Gavatron's right.
    Originally I just bought the pistons & rods on ebay coz I wanted ceramics.
    When I met the guy he offered me the block that the pistons came out of plus heaps of other stuff at a good price so I went for it, which meant I got oils squirters as well.
    I figured as far as cylinder wear goes it'd also be a good idea to put the pistons back in the same block they came out of.
    So... what's changing from 8.0:1 early GZE pistons to the 8.9:1 GZE pistons gonna mean in terms of power?
    Has anyone got any weblinks so I can teach myself about compression ratios?
    Chiba
    It means more power and you need to use 98 octane fuel.
    Aug 2009
    Sweet - I'm using high octane on the 4afe with extractors at the moment - she seems to like it.
  8. #38
    Dec 2010
    Northern Territory
    no worries guys all this is helpfull to me so thanks for the info
  9. #39
    Aug 2009
    Quote Originally Posted by dangdang View Post
    Thanks Dang Dang - it's very basic when you put it like that..
    ..& using one of those triple steel cometic racing gaskets...
    I'm guessing they increase the compression ratio a fraction more than a standard head gasket..
    If that's the case, does anyone know how much more the compression ratio is increased?
    OR
    is it just a stronger gasket that will generally last longer?
  10. #40
    Sep 2009
    Not in the slightest, it has many factors determining whether or not it will last, how it is prepped& installed being one of them.
  11. #41
    Aug 2009
    Quote Originally Posted by Casey-G View Post
    Sure sure.. Let's say all the prepp work's been done good n' proper - I feel confident a steel gasket would handle hard driving more than a common gasket. The mechanic I bought my bottom end off had an AE86 he did drift racing in up in Benalla, he said one of the first mistakes he made was blowing a head gasket because he just used a standard one.
    That said I've heard the standard one is very good & to be fair the guy mentioned above was pushing well above 200kw
    I've purchased one of the triple layer gasskets - I'm pretty sure it's .040" thick
    Not sure how that thickness compares to a standard one or how much it increases compression.
  12. #42
    Sep 2009
    Standard head gaskets are fine if used correctly. Saying something like the mistake was to use an OEM one translates to kinda a bad excuse for not torquing the head right/bad tune.
    A metal head-gasket won't hold up all that much better than a OEM one from a decent knock/poor install.
    40thou is a standard size HG for a 4age at 1mm, 4afe HG's are supposedly .8 which makes for a cheap compression up for the daily hack if you ever need to.
  13. #43
    Aug 2009
    Yaeh.. I dunno Casey, I can't really speak for the guy as a mechanic, he's just who I bought the gear off.. & that's what he said happened on his first 4age ..he also blew a piston through a block on his 2nd 4age that had a billet crank in it which he claimed was producing 300kw... He was a pretty funny guy, he definitely sounded like he pushed everything to the limit..
    Sold me the gear cause he was changing to rotary - couldn't get the power he wanted out of a 4age
    Ok here's where I'm a greenhorn again
    What is meant by "at 1mm" ?
    I don't quite follow what you're saying about the 4afe gasket...?
    I'm guessing you're saying a 4afe headgasket can be used as a rough cheapy mod on a 4age to gain a little more compression. ??
    Sorry if I sound a tad slow - I'm admittedly new to all this..
  14. #44
    Sep 2009
    Sorry i meant 7afe, but yes apparently the headgasket is .8mm from the factory which is thinner than a 16v 4age HG from factory (1mm) but have the same oil/water/bore and bolt holes aka are a match, therfore is you own say a ae92 sx/gti with a 4age, you can bump the compression up on the cheap by buying a factory replacement 7afe HG instead of a "cometic/TRD ect" .8mm head gasket.
    I'd like to meet the guy, cant believe everything you hear till its from the mouth (no offence) i know 300kW is easily doable on a stock bottom end with a 4age.. maybe he underated the toyo factory gear by mistake
    seen a dyno sheet from a guy over in NZ with a 4agte hatch, pushing 32psi though stock gze internals with a blacktop head making in excess of 350kW at the front treads so its deffs doable.
  15. #45
    Jul 2007
    stock 4AG headgaskets are actually 1.1mm if i remember right
  1. 4agze head gasket size?
    By johan_oern in forum Tech and Conversions
    Last Post: 25-09-2009, 05:29 AM
  2. 4AG head bolts - crack crack
    By Grega in forum Tech and Conversions
    Last Post: 28-02-2008, 08:54 AM
  3. 4AGZE Piston and 20V Head Volume
    By Bazooka in forum Tech and Conversions
    Last Post: 20-10-2007, 06:30 AM
  4. Fitting BT 20V head to 4AGZE Block
    By KOV51 in forum Tech and Conversions
    Last Post: 07-09-2007, 06:21 PM
