Page 1 of 4 123 ... LastLast
Results 1 to 15 of 54
Thread: 4agze extractors on a 4ag head?
    Dec 2010
    Northern Territory
    Default 4agze extractors on a 4ag head?
    im currently in the process of building an AE82 corolla sedan and have recently aquired a 4agze engine minus a supercharger and i am rebuilding the block with the hope of putting a 4ag carby head on it. first question is weather or not this is possible? second question is if it will work, will the extractors off the gze head fit the ge head? any help is appreciated. as the sooner i get this car back on the road the sooner i can start the
    4age 20v conversion on my AE86 levin.
    Default Re: 4agze extractors on a 4ag head?
    Quote Originally Posted by luke ae86 View Post
    There is no difference (from what I can remember) between a GE and GZE head, so extractors will bolt right up. There's no such thing as a carby 4AG head though (unless it's a modified one), they were all EFI from factory.
    Sep 2009
    Quote Originally Posted by Hiro View Post
    This man speaks the truth.. no difference at all.
    only thing i can think of that may be different is the location of the o2 sensor? maybe?? never owned a bog stock 4age, thought i'd just mention it.
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    Hi Luke,
    I wondered when I would see you post on here!
    Found this link while trawling around, might be of use:
    http://www.toymods.org.au/forums/arc...p/t-26718.html
    Also this link is usefull to find out the potential/benefits of different engines:
    http://www.sssautomotive.com.au/Engines/toyota.htm
    The biggest problem I can see mate is the fact that the Z motor has lower compression, to componsate for the boost of the super charger. Without the charger you wont be going anywhere fast, but the intenrals are stronger in the Z motor.
    I reckon you should just get a SC14 Supercharger, and set it up in a suck through carbied set up, or blow through if you can be bothered pressuring your carby. If you want to go this way let me know, I have been doing heaps of research for the turbo 'Rona project.
    Kind Regards,
    Ryan
    Dec 2010
    Northern Territory
    Hmm. This is puzzling and of slight concern. I was talking to the owner of a local workshop that specialise in cylinder heads and he said the 4ag (not 4age) did not come with holes for fuel injectors and that it was a carb head similar to a 4af but not the same. So i am unsure what the go is there? I asked for a smallport.
    And i am aware of the underlying issue of low comp pistons hence the rebuild so there should be no drama.
    Just a thought, would the extractors in question fit a 4afe/4af head?
    He's probably thinking of the 4AC head. Every 4AG 16v head has holes for the injectors.
    Or maybe the 4AG 20v head, which has the injectors in the manifold.
    www.billzilla.org
    Toymods founding member #3
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Quote Originally Posted by Rhyno View Post
    Only difference between a smallport and a gze bottom end is the pistons, which are just lower comp with a coating on them. Crank and rods are identical.
    Sep 2009
    lol oh fck i just read its an ae86 and that its a 20v head?. all 4agze's were FWD, the extractors will not work on a RWD car.
    4agze extractors are 16V, so wont bolt up, regardless neither will work on a rwd conversion.
    RE: 4af:
    4ag(z)e extractors do not fit on 4afe's 4afc's or 4ac heads.
    Adelaide, SA
    It's an AE82 sedan...
    Sep 2009
    Quote Originally Posted by Gavatron View Post
    lol,
    Sorry man, just finished work tired as, need a beer.
    Chiba
    The best 'stock' extractors you can get are the blacktop extractors, but you'll need the secondary pipe too.
    They will fit a 16v head with the addition of two holes in the flange.
    Learner / modder / Backyard Mechanic PrettyCoolWagon's Avatar
    Aug 2009
    What about the oil squirters & 7 ribs in the cast iron block of the GZE?
    Do GE's have those?
    Quote Originally Posted by PrettyCoolWagon View Post
    Do GE's have those?
    Yes. GZEs have always had the same bottom end and head as their equivalent year GE, just the pistons are different.
    Jul 2010
    Hiro is spot on the money
    I did heaps of research befor buying my smallport
    The bigport has smaller crank,rods and is only 3 rib
    The smallport is 95% the same as the GZE with just the pistons different !!!
    Smallport injectors are in the head !! if thats any help
    If you need any Pic's of a 4age smallport just sing out and ill post anything i can
    Ae90 Hatch 4AGTE Small port http://www.toymods.org.au/forums/showthread.php?t=64566
    Same car More info http://www.toymods.org.au/forums/showthread.php?t=63892
    LAUGH NOW CRY LATER ! Cars and Girls will do that to you !!!
    Quote Originally Posted by Adams4AGTE View Post
    Only true of the early bigport 4AGEs. The later bigports (and the bigport 4AGZEs I believe) are 7-rib and same size crank/pin as the smallport.
  1. 4agze head gasket size?
    By johan_oern in forum Tech and Conversions
    Last Post: 25-09-2009, 04:29 AM
  2. 4AG head bolts - crack crack
    By Grega in forum Tech and Conversions
    Last Post: 28-02-2008, 07:54 AM
  3. 4AGZE Piston and 20V Head Volume
    Last Post: 20-10-2007, 05:30 AM
  4. Fitting BT 20V head to 4AGZE Block
    By KOV51 in forum Tech and Conversions
    Last Post: 07-09-2007, 05:21 PM
