seems to be the best place to write this... so..
..i had my first go at painting with a gun today. always just done touchups with rattlecans, and had no trouble. but doing bigger things needs more paint, and it is just cheaper and easier to use a gun for that.
have gathered all the shit i need to prime and paint, and thought it was worth a crack. have a cheap suction feed gun i was using for priming, and bought a new grav feed with a smaller tip to paint with.
been sanding all the shit smooth for the last week, prepsol'd it all, and layed it out to be painted. all's sweet.
since its a plastic lip and side-skirts, i bought a tin of K&H plasti-prime. took the lid of the tin - and god its thick! looked like some sort of goo. grabbed a screwdriver and stirred it up for a couple minutes... looked better.
poured 200ml's into a measuring cup, then about 170ml's of K&H general purpose thinners... since thats what it said to use at .5 to 1:1 ratio. stirred it up.. and now it seemed more like a paint than a goo.
the gun i used is a supershit auto spec 'scorpion' suction feed gun. read the instructions, and figured which knobs adjust the overall air it uses, how much paint to air, and the adjustment of spray pattern.
poured the paint into the gun's tin, plugged it into the compressor at just over 3bar (~40-50psi), and away i went:
BUT, at first it seemed to be spraying waaaay to fast... so i turned the pressure down on the gun. seemed better, so i started painting. problem i found was that it was just to airy for the paint. i adjusted the paint-air ratio knob untill it popped off the back of the gun. was shit.
so the paint is very very rough.. used it all up doing this, mixed up a second batch of the same, and kept going. then i realized that the paint was practically coming out of the gun like a spray on carpet. spraying it into the air made it look like streamers of some shitty fur.
now this is where i was left very dissapointed and wondering where i fucekd up.
- why is the paint coming out so dry? does it seem this way just because im not spraying it on thick enough?? is it too much overspray making it seem like its coming out rough and dry?
- why was the paint spraying out so badly.. like fluffy streamers of somesort...
i decided to stop it all there, before i sprayed on more shit paint id have to remove, or waste any more paint.
so i started to clean it up. took the tin off the gun and straight away realzed that the paint was drying in there. it was like leather.
- had i not mixed the paint right? or had i just left the gun too long and let it dry?
it almost seems as though it had seperated in the tin, and i was only spraying thinners from the second batch..
i guess now im going to have to sand smooth all the paint ive put on, and clean up any mistakes. im going to give it another shot in the next few days, so any help would be GREAT. please? ..i hope i explained the problems well enough.![]()
