Page 36 of 139 FirstFirst ... 2634353637384686136 ... LastLast
Results 526 to 540 of 2085
  1. #526
    Depends how thick your primer ends up, if you have any really thick spots, you will need to let the primer finish stretching and waving before a colour can go on. Primer does far different things when drying compared to colour.
    Not sure how they did the crows feet on my RA28, but that was done by a professional shop (some time ago now). The best paint on the whole car is the wafer thin layer of factory paint left on the roof. If I polished it, it would become primer.
  2. #527
    May 2008
    so is it ok to say etch prime the metal then use filler over that......Im using Evercoat rage gold which can be applied to paint or metal....paint must be sanded though....
    1992 - JZA70 STOCK - SOLD
  3. #528
    Quote Originally Posted by GA70H_92
    Yeah with any filler/bog the surface must be sanded/roughed up, this to ensure the bog has something to grip to . Personally I would etch the bare metal, let that flash off, then spot prime those areas, then sand, then fill/bog.
    Evercoat Gold and PPG Microfine are pefect for filling over a primed surface.
    cheers Chuck.
    MS51Crown Coupe,
  4. #529
    May 2008
    cool stuff! I will etch prime all bare metal surface then coat of primer then roughen up then bog work the more primer(primer filler or standard?) then colour coats then clear then hope it looks good
  5. #530
    Nov 2007
    Hi guys thanks for the great thread read the hole thing a few time now.
    Im looking for a compressor and wondering on which 1 to buy. I will be using it to spray my car. Looking to spend about $300
    Thanks
  6. #531
    Rosewood
    I cheated on the compressors.
    I have 1x 40litre compressor and 2x20litre compressor, all relativly cheap. And the are all plumbed together to a single regulator.
    So i have 3 air pumps, and 80 litres worth of storage. Seems to work fine for what i was doing. And they were all relatively cheap 2nd hand compressors.
  7. #532
    Geoff, try the trading post, to get a decent compressor for that kind of money, you will be looking secondhand.
  8. #533
    Nov 2007
    What Bands and sizes should i be looking for?
    Belt Driven or piston?
  9. #534
    Belt driven, at least a twin piston pump (V twin will give slightly better heat dissipation), and at least 50L tank.
  10. #535
    May 2008
    would 2 litres of mica paint, clear, primer be enough to do a 2 rear panels a rear bumper and a targa roof for a supra???
  11. #536
    Certainly should be enough.
    cheers Chuck.
    MS51Crown Coupe,
  12. #537
    May 2008
    cheers....got to say primer work and bog work suck......at least out come will have less ripples and bumps.
    And to anyone doing bogwork use Evercoat RAGE gold easy to shape and sand....and a 3.4 litre tin costs about $45 cheaper then that supershit crap which goes rock solid!
  13. #538
    so, im spraying mine with spray pack cans
    now.. seriously.. it goes on 10 times smother if you put the paint can in warm water before you coat it on. and also if you have the panel warmed from behind with, i dunno a radiant heater. it seems to harden the shit pretty good too
    so if your doin the dodg like me its something to think about
  14. #539
    GA70, where do you get the Evercoat from??
  15. #540
    May 2008
    Oman...Total Paint Supplies or when im in melbourne I go Paint place in Glenroy
    Last Post: 06-01-2010, 09:34 PM
    Last Post: 23-09-2007, 12:52 AM
    Last Post: 11-01-2006, 10:53 AM
