Page 313 of 392 FirstFirst ... 213263303311312313314315323363 ... LastLast
Results 4,681 to 4,695 of 5875
  1. #4681
    Quote Originally Posted by Sagluren View Post
    im sure i have something, more than welcome to come grab one, one day...
    i should have atleast one good pump i have four engines...
    cheers sam
    Well if you've got one that's already removed i'll come up and grab it one day, maybe I can take a few other bits and pieces off your hands. Ra35GT is having a poke around the shed for me also I believe.
  2. #4682
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    ill have a look tonight if ive goot out of a engine, if not i can get one out..
    ill let you know..
    cheers sam
  3. #4683
    Aug 2012
    Whats the most powerful 18rg turbo ever tuned? I know it would only be a drag or dyno queen engine but just for interest sake as I cant find it on the search. They definitely have massive potential been a better revving mini keith black head.
  4. #4684
    Top End
    not sure on the figures but i bet this motor is up there
    18RG KE20 Corolla 9.10 & 148mph
    http://www.youtube.com/watch?v=--X1tQKj1b0
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
  5. #4685
    Aug 2008
  6. #4686
    south australia
    i was going to put the unda presha vote in..
    cheers sam
  7. #4687
    Aug 2012
    wow stock internals they are the best of toyota 4 cyl engines
  8. #4688
    Jan 2012
    Finland
    Well.. it's a 152 E but still a R-engine.. http://www.b20vtec.com/forums/track-...04s-video.html
  9. #4689
    Aug 2012
    what a great achivement! if only it was as big in capacity as an offenhausser
  10. #4690
    Hi Guys,
    I'm piecing together my 18RGEU, while this is not my first foray into 18R-G power, this is the first time i'm trying to set up an injected motor, let alone using the complete factory injection, ECU and emissions gear. I've pulled all the manifold apart and need some help identifying a few bits and pieces.
    For those who need the reading glasses, left to right
    Red circle - coolant lines for the throttlebody - one line goes from the manifold coolant outlet - the other goes where?
    Orange circle - Positive Crankcase Ventilation port - from the PCV outlet on the cam cover to the plenum
    Yellow circle - Fuel Pressure Regulator vacuum feed port
    -coldstart injector-
    Green circle - IACV port
    Light blue circle - ....there was a hose that tee'd into the IACV pipe that goes here on the vacuum actuator dooflicky. This is the main thing i'm chasing more info on
    Dark blue circle - I have no idea what this is for, was connected to an electronically operated vacuum solenoid, so I can only assume it's some kind of 'idle up' valve for the... air conditioning, at an educated guess? No idea where / what they should be connected to.
    Purple circle - Brake booster vacuum feed.
    Anyone care to fill in the fuzzy patches?
    This is the vacuum solenoid that one of the light blue circled ports was connected to
    Also, the fuel injectors -
    These look like they're standard kit. They sure look and feel old and weighty enough. Can anyone confirm? Also, as for re-kitting these with a set of new seals, does anyone have any suggestions as to which injectors may share similar seals (obviously with the 18RGEU not being sold locally in any kind of volume, a seal kit won't be available) so I can order a complete kit?
    Any help appreciated to get this old lump ready to drop in the car
  11. #4691
    Aug 2008
  12. #4692
    My comments added below in BOLD mate!
    Quote Originally Posted by Javal View Post
    Hi Guys,
    The other goes to the front steel bypass line thing that runs under the head from the thermostat housing to the water pump
    This connects to the IACV supply line (for filtered air)
    You are correct, it is an idle up valve, triggered by A/C, small port to the vacuum switch (which connects to solenoid) the other one connects to the solenoid as the vacuum source
    They look like the standard ones on my car, I'd suggest trying toyodiy and looking up a corona (http://www.toyodiy.com/parts/p_J_198...EMQF_2211.html) Then giving part numbers to Amayama/Toyota to check availability etc. I just sent my injectors to a fuel injector place to get cleaned and have new seals put on, cost like $40 though).
  13. #4693
    Jan 2012
    Finland
    The coolant line is there just to prevent the icing the throttle.Yes,it can freeze and stuck and factory have to consider it for safety reasons.You can leave it unconnected.
  14. #4694
    Forgot the main reason I opened this thread.
    What options are there for forged rods for our beasts!?!?
    (Yes, I realise it's not really required, but I figure a bit of extra insurance couldn't hurt if it isn't too exxy! and more boost is always better right??)
  15. #4695
    Aug 2008
