Page 23 of 392 FirstFirst ... 1321222324253373123 ... LastLast
Results 331 to 345 of 5875
  1. #331
    AFAIK the purpose of the balance tube is to get a stable vacuum signal, as it is joined to all four inlet ports which are usually separate.
  2. #332
    Thats the 16valve 18rg head brett
    EDITx2:
    -thanks norbie
    -actually, it is 2TG 16v
  3. #333
    Buenos Aires
    I am really not familiar with engines with individual throttles as you are (you have many EFI cars like that around there). Is it common that they have this "balance tube"? I really think its only purpouse (or at least, main one) is letting oil fumes from head and crank-case enter the engine.
  4. #334
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Guys, i'll have a chat to Mr Revhead today.... i've already got myself and Norbie down for some timing chain parts, but it's not really worth group buying with the new under $1000 customs duty exemption.
    Im pretty sure you can each individually sort it out with him directly, will let you know during the day.
    Steve
    i picked out these p/n's myself from an online EPC that is no longer available... damn russians! i picked an RA63 carina from memory with 18rgeu.
    ..... and just cos i love you so much steve, i drew you a picture explaining my terminologies....
    hey karl,
    i need a new tensioner that pushes against the hinged guide to make the chain tighter,
    its the blue thing marked no.2 tensioner in that picture above,
    can anybody help
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
  5. #335
    tasmania
    yeah good luck! i made my own, i knew that it would be very hard and expensive to track one down(tassie anyways)
    beer me!
  6. #336
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    Quote Originally Posted by DQIKST
    hey karl,
    can anybody help
    You can use 4ME and 5ME Upper Timing Chain tensioners...they are a direct fit, I have one in my 18RG now. 5M-GE obviously won't work seeing as it has a timing belt. 3TGTE and 2TG also supposedly fit but I don't have first hand experience.
    These are the cars I found to have the 4M/5M engines...
    Cressida MX62...............1983-85...5M
    Crown MS65..................1971-76...4M
    Crown MS83,85.............1977-80...4M
    Crown MS111, MS112...1977-83...5M
    Crown MS123...............1983-85...5M
    Supra MA61.................1983-85...5M
    SWS Motorsport sell "18RG" tensioners for $51, however these are simply refurbished/cleaned 5ME ones, as the one I bought off him was identical to the one i found at the wreckers for $10.
    The 4M/5M tensioners require one slight mod, you may need to cut down the length of the shaft to match your 18RG to ensure correct tension. Couple of minutes work with a dropsaw.
    Hope this helps man!
  7. #337
    tasmania
    i wish i knew that! i had one of them. they look different though.
    beer me!
  8. #338
    Yeah the outer housing is a different design, but the thread is the same, oil holes etc...
  9. #339
    and apparently they look ugly, any one got a pic?
    +rep for u already major although i am going to see if a 2TG would fit in an 18RG
  10. #340
    tasmania
    they're pretty gay lookin, just a slightly tapered shaft about the same length with a nut and slotted stud on the end(like a rocker adjustable screw thing). that is if the 4ME has the same as the early(pre-pollution) 4M's. i believe they are.
    if you get stuck i've got one from both 4M's that you can have.
    if no-one posts a pic tonite i'll get you one tomorrow and i''l check the threads/measurements.
    beer me!
  11. #341
    Hey guys,
    Can someone please confirm that these carbs are 44mm P5 Solex's?
    See the metal plate sitting on top of the two carbs that connects to the accelerator cable? I took it off and underneath there is 'MIKUNI' engraved so it must be a factory item... Anyone seen that before? I certainly haven't...
    The close-up pic is taken without the metal plate.
    Ren.
  12. #342
    tasmania
    Quote Originally Posted by Ren_RG28
    Hey guys,
    Ren.
    they all look the same.
    they usually say what size they are on the body near the butterfly end.
    failing that, you can take an air filter(simple in most cases ) off and measure one of the throats.
    beer me!
  13. #343
    User Conversion King
    NWA
    Hey guys,
    Ren.
    they definately look like the earlier model mikuni's..... identical to the set that were on my 88253 head no. engine. i also had a 88253 18rg engine that had the crap carbys with the bi-metallic bleed valve and pollution crap
    as suggested though, remove an air filter and whip out the verniers
    hello
  14. #344
    Look like later style 40mm for the 18R-GU engines. They're not the same as the early 210 and 230 head 18R-G engines.
    seeyuzz
    river
  15. #345
    NWA
    river,
    i believe the they are from a earlier model 18R-GU, not the later ones. one of the 18rgu's i owned (88253) had identical carbs and another had the pollution carbs. as far as i know it, toyota were trying to reduce emissions so its likely the pollution carbs were on the later 18rgu's
    hello
