Page 25 of 392 FirstFirst ... 1523242526273575125 ... LastLast
Results 361 to 375 of 5875
  1. #361
    Quote Originally Posted by TOSCO
    DCOE's on a ported 18RG 2nd gen manifold would out compete pretty much any custom efi setup.
    I'd put money on 45mm ITB's outperforming 45mm DCOE's, all else being equal.
  2. #362
    I second the midget of the north.
    I will also state that whilst MAD79R makes more peak power on the dyno - i kill him on the track. His 16.5 versus my 15.8.... add to that the extra power i have over any DCOE setup at the lower end of the scale (ie everyday driving).
  3. #363
    Forum Member Grease Monkey scootaphill's Avatar
    victoria
    i feel compelled to add that my poorly tuned (poor cam timing that is)18rgeu has 74.6rwkw. Given a few more months to sort out my new shed so as that it actually has power and lights i can then play with her. Im looking for a min of 15rwkw gain, but like everyone else hoping for more.
    Phill
    ON HOLD Current Project 1UZ-FE Powered Buggy
    Last Project 18R-GEU time to tinker
    EDITED ITS ALL VERY LAMO
  4. #364
    The track times probably have more to do with his car being heavier and possibly different gearbox/diff gearing.
    seeyuzz
    river
  5. #365
    south australia
    can valve guides still be acquired for the 18rg? (not the valve stem seals as they come in the complete gasket set, I am talking about the guides that are placed into the headthat the valves fit inside).
    Obviously i can ask toyota, but i am hoping that is not the only option.
    Is it possible other valve guides may fit?
  6. #366
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    barned01
    A head or engine reconditioner should be able to get them for you, probably put them in for you a reasonable $ if you have the head stripped.
    regards
    jon.
  7. #367
    Quote Originally Posted by barned01
    Yes they can.
    I got some genuine ones a couple of months ago, fully finished items for $108.80 for the set, but I think that was trade price. Part number 11122-88250
    ACL also do 18RG valve guides for the 8.5mm stem. I think they were fully finished (no internal fitting work required) but am not 100% sure. I don't know what the price was for those.
    New main bearing bolts (90910-02042) were also available at the time through Toyota and also 22R flywheel bolts (18RG might be available too).
    Best of luck with it, I got my parts from Robin at Peter Davey Toyota in Prospect.
    (\__/)
    (")_(")
  8. #368
    south australia
    really? acl do stuff like that?
    well that begs another question then before i go down to sprint auto.
    The valves for the 18rg are a non normal size apparently, does that mean that i could use a different valve guide to get a different more common diameter valve to fit or am i thinking too far outside the lines.
  9. #369
    failing that, 3L ones can be used, but will have to be top cut
    The boobs are back
  10. #370
    There is a larger variety of valve sizes available in 8mm stems than in 8.5mm.
    The L series diesol engines and the 3R(I think) are some of hte very few engines that do have 8.5mm stems.
    I'd only look into 3Rs if you wanted smaller valves for some crazy reason though.
    (\__/)
    (")_(")
  11. #371
    south australia
    are 3L valves plentiful to come buy and suitable as replacement vlaves in an 18rg or is that what Mr DOHC is talking about when he says 'fly cut'?
    (diameters of vlave face same, valve stem length same etc.)
    i have a spare head coming over from queensland with vlaves in it but if it is more worthwhile for me to spend a day at UPI seeing if i can take out people's eyes with flying collets then that sounds like much more fun
  12. #372
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    yes that is the perfect setup of stock bits. The Solexs will give the most power, but the EFI will give the best useable power and far superior fuel economy.
    I have close to this setup in the '28 right now.... 9.7:1 pistons, 88253 head, but 88250 cams..
    The next trick is finding some of the rare 44 Solexs.... me being the carbie moron that i am i have no idea if the two different sets i have here are 44s, ones a set from an 88210, the other from an 88253.
    RE SOLEX. HM do you want I have three sets one in service two sets spare.
    First series were repairable and had removable venturis also had choke setups which worked loose as they were fixed in place by 10MM bolt and a locking nut on the side of the barrell.
    Second series had cast venturis inside the throat and not removable but not repairable.
    Running original Solex-Mikuni's 21100-88232/88233 which were reshafted at 235000 km and are still running the car economically.
    FYI
    44 and 40 have different venturi other wise same except for JETS air and fuel. I run 125 Fuel 80 air.
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
  13. #373
    Any wiring wizards on 18RGEU, check out my Wiring Woes thread... not for the 56Kers as its got alot of photos. HAving a bit of trouble...
    http://www.toymods.net/forums/showthread.php?t=12506
  14. #374
    I will take a look what exactly is the problem you need to fix.
    18RG owner for 240,000 km, since December 1976.
  15. #375
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Quote Originally Posted by RT104GT
    FYI the compressions are 175 175 170 175 at this time.
    down about 5 or 10 psi since 1980
    i dunno what pistions i am running but i have 40mm solex carbies and a 88253 head other than that i think everything is stock and i think i have to do my rings because my compression reads
    110, 90, 110, 120
    i will be doing a wet compression test tomoro to see if it is pistions or rings
    DQIKST
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
