Page 13 of 392 FirstFirst ... 311121314152363113 ... LastLast
Results 181 to 195 of 5875
  1. #181
    will cliff cover my travel expenses?
  2. #182
    i'll see if he has an email
    The boobs are back
  3. #183
    Sydney N.S.W
    Since you guys on this forum have assisted with my ra28 rebuild, I found an old book I have with some info that may help.
    specs for 2tg & 18rg
    rebuild parts no's for 2tg 18rg
    trd engine bearing applications
    oil pump part no's
    mikuni carby part no's & jetting recommendations (stages1,2,3,4)
    trd flywheel applications, variety engins Eg 18rg
    transmission ratios std part no's & trd No's w50, t50 series
    plus theres other info not sent eg nos applications guide1600cc to 3000cc with efi
    bore x stroke hp @rpm ,specs on most engines
    ignition converions to electronic with part no's 18rg 20r 22r .t series etc.
    trd header applications & part no's most models
    trd high perf clutch apps with part no's
    trd brake pads and part no's most toyota's
    trd suspension front & rear most models Including celica 71-77 78-81 gt-st82-85 gt-s83-85
    shocks high pressure and low pressure shocks . & adjustable
    And performance suppliers mainly from the US
    If there's an interest in any of these items, drop me a line.
    and more how too's
    regards
    Ive noticed they might be hard to read because I've shrunk them a bit.
  4. #184
    hey Omegaman.
    can you email me the pictures. As you said they are a little small to read. Thanx
    [email protected]
    Adam
  5. #185
    I can host the full-size pictures if required.
  6. #186
    sounds good norbie!
  7. #187
    Sydney N.S.W
    norbie I've sent you the toyo info,to do as you will.
    Also adam (ke30) I've sent them to your email add too.
    They are interesting.
  8. #188
    Forum Member Grease Monkey scootaphill's Avatar
    victoria
    How much does an RG weigh? just out of intrest
    phill
    ps karl howd your wiring turn out... hope my diagrams helped
    ON HOLD Current Project 1UZ-FE Powered Buggy
    Last Project 18R-GEU time to tinker
    EDITED ITS ALL VERY LAMO
  9. #189
    Thanks for that Omegaman.
    For those who want to see the full-size pics, click here. Dial-up users beware, some of them are over 1mb.
  10. #190
    Omegaman on page six before it talks about Mikunis it talks about webers.
    I don't suppose it has jetting recommendations for them as well?
  11. #191
    While I should really put this in the Wanted section seeing as it is an 18RG thread only it seemed a good place to ask about anyone with a set of second hand leads for an 18RG. They are for a friend in the US.
  12. #192
    Sydney N.S.W
    Turdinater, there no info on jetting for webers.
    I have attached previous pages 75, 76 to go with page 77.
    See How you go, it does suggest how easy it is to change the jets.
  13. #193
    OK, so the vacuum advance on my new 18R-G isn't working. I've been experimenting with a timing light and hooking up the diaphragm to different parts of the manifold (including parts which definitely have vacuum) and it makes no difference whatsoever to the timing. If I manually push in the plunger the timing advances plenty so the advance mechanism is working fine, it's obviously the diaphragm which is stuffed.
    Anyway I pulled the diaphragm assembly off the distributor hoping it would be fixable, but it's a sealed unit and there appears to be no way to get inside it without destroying it. This means I need a new one - but where from? Does anyone know if other Toyota distributors have a compatible vacuum advance mechanism? I'm going to the wreckers on the weekend to see if I can find anything similar (22R perhaps?) but I was hoping someone might know. Help a brother out, my Celica is so slow at the moment it's almost dangerous to drive!
  14. #194
    i have an 18R dizzi (complete with a pertronix hall effect pickup and igniter) with a functioning advance unit if it helps - will swap for information on:
    -rotation of crankshaft (has been so long i forgot) when looking at it from front of car
    -markings on 18Rx pulleys (which if the 3 is TDC)
    -whether the keyway in the 18R cranks is vertical at TDC or offset towards the drivers side
  15. #195
    chuck
    1. facing engine, clockwise
    2. facing engine, furthest left
    3. vertical, IIRC
    norb... i'll get to that vac advance now. Lucky i'm nice hey?
