They are built like a brick shithouse, though Witlz managed to break a few.Originally Posted by jak
You should be able to get 200-220rwKw from a good turbo'd 18R-G.
But you should put in forged pistons, rebuild the engine, new bearings, check the crank balance, etc before you want to pull that power without somehting going pear shaped. You also need a decent ECU to go with the system, as well as injectors and fuel pump.
I'm currently getting an 18R-GUE rebuilt from the ground up, with custom manifolds. Probably run the latest Wolf ECU. I want the turbo to start working around 1800rpm to suit the type of driving I will be doing, so I just need a smaller turbo - like a GT25R. This will get me around the 170kW range, which is plenty better than the 39kW of the current 18R-C engine.
seeyuzz
river
