Results 61 to 64 of 64
Thread: 3T and 3T-GTE CrankS
  1. #61
    Jun 2010
    paskaoja3 aass
    Default Re: 3T and 3T-GTE CrankS
    Bells are usually made of cast metal ..
  2. #62
    Feb 2012
    Wa
    Hi everyone this has nothing 2 do with the thread but still a 3tgte! Do I need 2 run or plug in the knock control and the pc and pe units?
  3. #63
    nuts Grease Monkey
    auckland
    better to ask that in the 3tgte tech thread
    http://www.toymods.org.au/forums/tec...-gte-tech.html
    you don't *have* to run the knock control as it is a failsafe system and doesn't affect the operation of engine when engine running normally, and it may not work anyway due to age. afaik the knock control has only one wire to the ecu and if left disconnected wont retard the ignition timing.
    Can run without fuel cut (recommended) by either disconnecting the vacuum hose or earthing the wire for the fuel cut pressure switch (Pc).
    Fuel enrichment pressure switch can be removed and it just wont add extra fuel when on boost. but suggest to check a/f ratio is safe with boost.
    Knock control details here
    http://www.toymods.org.au/forums/tec...fo-wanted.html
    -Mark
    E2 + E7 fan
  4. #64
    Feb 2012
    Wa
    Thanks 4 the info!
  1. Billet 3SGTE cranks, interest?
    By -Totenkopf- in forum Tech and Conversions
    Last Post: 22-07-2011, 02:41 PM
  2. who makes billet 3sgte/ge cranks
    By Celica RA45 in forum Tech and Conversions
    Last Post: 29-06-2011, 08:28 PM
  3. 4age cranks
    By bp18t in forum Tech and Conversions
    Last Post: 05-12-2009, 07:10 AM
  4. Z20 Dash turning off when engine cranks
    Last Post: 11-05-2009, 09:36 AM
  5. T series counterweighted cranks
    By Turboterrifik in forum Tech and Conversions
    Last Post: 30-08-2006, 04:44 PM
