Results 16 to 30 of 69
Thread: 1UZ minus AC and PS?
    Default Re: 1UZ minus AC and PS?
    That was my concern when I first saw Ed's setup, however I never heard him complain.
    That could be an issue with high alternator loads like you say, but in my case I doubt there would be much of a drama. The Hilux is rather simple when it comes to electrics.
    Thats about the same wrap around as a JZ engine, so i see no issue.
    Apr 2007
    Takai, i just checked my JZ engine & it definately has noticeable more belt wrap than ED's setup, i would say its about the same as factory 1UZ setup, which makes sense as well as they both run a 6PK belt ..
    One way to tell is to run a setup like ED's put it under medium loads & occasional high loads for a while, then shut it down & check the temperature of the pulleys, if they have been slipping they will be very hot, if not they will be quite ok temp wise & good set up to use ..
    Quote Originally Posted by Norbie View Post
    You'd be surprised just how much load goes on an alternator when the battery is half flat, the headlights are on, and a pair of thermo's kick in.
    Thanks for the info everyone! I like what Ed has done, that's a neat solution. I'm off to the wreckers to find a 7M water pump pulley - and if it's the wrong size I'll come back here to complain.
    Yeah i did what Ed did but with a full alloy fabricated pulley...local machinist whipped it up.
    Feb 2009
    remember what it cost ??
    Does it have to be heat treated at all???
    Quote Originally Posted by lexsmaz View Post
    Yeah, just looked at a picture and was thinking of the water pump.
    The factory 1UZ has at least 180deg of wrap on the alternator.
    JZ has probably 150deg
    Penrith BC
    i did squeal with the 875 belt when the rad fans initially kicked in, then gripped again, and stopped. the 875 belt did put the tensioner right at the softest end of its throw though. i then tried an 855 belt and have zero slip problems. the tensioner still has more spring travel left, but its much better
    ../delete/ban
    tech moderator
    Quote Originally Posted by matty12 View Post
    I sold it for $80...can't recall what i paid. No heat treating required.
    Any comments on the pros and cons of permanently removing the front covers off the engine, thereby getting rid of several unwanted components? Can it be a bad thing having the cam belt exposed?
    Penrith BC
    i dont like that idea
    though i would make it look less like a victa
    ../delete/ban
    tech moderator
    Feb 2009
    im of the opinion the 5 0 may frown upon it,hello yellow.
    Last Post: 29-10-2021, 09:49 AM
  2. 1uz oil filter locations
    Last Post: 28-03-2008, 05:46 PM
  3. 1UZ VVTI... Wiring questions.
    By MWP in forum Tech and Conversions
    Last Post: 07-06-2007, 03:00 PM
  4. Replies: 23
    Last Post: 29-04-2007, 12:18 PM
