Results 46 to 60 of 69
Thread: 1UZ minus AC and PS?
  1. #46
    Default Re: 1UZ minus AC and PS?
    As i said my setup which was temporary worked ok and I only used a narrow belt as it was all I could get at the time
    Jealousy is a curse
  2. #47
    Alright well this seems to work ok
    http://www.youtube.com/watch?v=euKi8L9pkxw
    No signs of slippage, belt isnt ridiculously tight... might just get away with it
  3. #48
    Penrith BC
    i reckon thats going to slip like a mothafucker! like really really think thats not going to work my pulley wrap as per way earlier posts was *barely* enough, the belt was tight, and it DID slip on occasions. i ended up underdriving the crank and alt pullies to help make it more manageable.
    ../delete/ban
    tech moderator
  4. #49
    Mine worked with a narrower belt and less tension so that should be ok.
    Jealousy is a curse
  5. #50
    Bear in mind i dont have anything other than the electrical essentials in this car (no a/c, hifi, demister etc), also that i am using a bigger alt pulley than you Ed
    I loaded it up as much as i could (headlights, wipers, fans and full lock on teh PS) and there was no sign of slippage
    I was also a bit sceptical that this would work, only tried it as the easiest option. I'll keep the old alt-only belt in the car in case of emergencies
  6. #51
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    Quote Originally Posted by CrUZida View Post
    Hey CrUZida,
    Im guessing even that is for a 3UZ, its suitable for a 1UZ as well?
    I think I asked you this before, the ebay link to the old one is gone.
    Thanks,
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
  7. #52
    Yeah, they fit. they need a very slight mod though, but its no biggie
  8. #53
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    Hey Guys Though I'd revive this well and truly dead thread,
    Ive just completed the alternator only mod using a pulley from a ford falcon/fairlane injected 302 v8
    I went this option as sourcing a 7m water pump pulley was proving a little tricky.
    It has allowed me to use a 6pk850 belt.
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
  9. #54
    Apr 2007
    Looks like a neat solution & I have seen some one else do a very similar / same idea, to me the lack of wrap around the Alternator pulley looks to be a slip worry though in High Alternator load situation's though ..
  10. #55
    I will have to find out once its running, mind you if I find the 1uz to be not enough power in a 1050kg car, I will be forced to add forced induction and the belt arrangement will have to change again
    My Rides:
  11. #56
    Quote Originally Posted by bmxer54 View Post
    Kind of weird to login to Toymods for the first time in a very long time and find this thread on the front page which I started years back!
    Anyway looks like a very neat solution, I like it a lot better than the 7M solution. Were any modifications necessary or was it a straight bolt up?
  12. #57
    bloody hell he lives
    Or just do this and use a bracket off the alt as the tensioner....good belt wrap and one less pulley to worry about.
    Yeah Norbie, Straight bolt on job, needed a new pulley anyhow as my 1u tensioner pulley bearing was gone.
    Justen that is another way of doing it, and was considered. will see if i have belt slip problems before traveling that route though
    My Rides:
  14. #59
    Haha yep I still exist, just barely though.
    I like the simplicity of your approach, but the idea of having to manually tension accessory belts seems strangely retrograde to me. Have you had to re-tension often?
  15. #60
    Thanks for the information, very useful!
    Last Post: 29-10-2021, 09:49 AM
  2. 1uz oil filter locations
    Last Post: 28-03-2008, 05:46 PM
  3. 1UZ VVTI... Wiring questions.
    By MWP in forum Tech and Conversions
    Last Post: 07-06-2007, 03:00 PM
  4. Replies: 23
    Last Post: 29-04-2007, 12:18 PM
