Results 61 to 69 of 69
Thread: 1UZ minus AC and PS?
  1. #61
    Default Re: 1UZ minus AC and PS?
    Quote Originally Posted by Norbie View Post
    Haha yep I still exist, just barely though.
    I like the simplicity of your approach, but the idea of having to manually tension accessory belts seems strangely retrograde to me. Have you had to re-tension often?
    No, i can honestly say it hasn't needed a retension yet
    Thanks Justen, good to know.
  3. #63
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    Justen for your setup did you simply cut/file/machine 8 or so mm off the back of the top mounting tab and make a slotted 8mm thick alloy plate?
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
  4. #64
    No I had an alloy sleeve machined up to replace the mount I removed....it just left the long bolt from the head. Length to suit the slotted 8mm plate I made up for the tension.
    I'll try and take a pic from the side.
    Oct 2016
    Saskatchewan
    Hi I am having a problem with belt slipping with this design. I am thinking of making the alternator a swivel style and getting rid of the tensioner all together. Would more belt on the alternator get rid of the squeeling? Sorry for the old revive, but I am in a pickle. Thank you!
  6. #66
    Jul 2016
    Have you got a pic of the current setup. Might be able to give better advice
  7. #67
    Oct 2016
    Saskatchewan
    Hi Camos, I have the same setup as ED. I machined and welded the 7m water pump pulley on the tensioner. I'm running the tensioner, the alternator, and the crankshaft. We checked voltage and everything checks out.
  8. #68
    Jul 2016
    Make it easy for us dude, have to go and read the whole thread to find out what he is running.
    I did see he mentioned that he had slippage.
    Help a bro out and get a few happy snaps so we can all chime in. A lot of the old pics are now dead links
  9. #69
    Oct 2016
    Saskatchewan
    Okay sorry man. When I get to the garage I'll snap some. It's a little tight because it's in a Miata.
    Last Post: 29-10-2021, 09:49 AM
  2. 1uz oil filter locations
    Last Post: 28-03-2008, 05:46 PM
  3. 1UZ VVTI... Wiring questions.
    By MWP in forum Tech and Conversions
    Last Post: 07-06-2007, 03:00 PM
  4. Replies: 23
    Last Post: 29-04-2007, 12:18 PM
