Results 46 to 51 of 51
Thread: HELP!- 3SGTE diagnosis
  1. #46
    Apr 2010
    canada
    Default Re: HELP!- 3SGTE diagnosis
    Ince u mentined the wastegate...on the wastegate there is 2 hose comin out the top.one of them has a cap on it,it's blocked is that normal?
  2. #47
    Severely Underqualified Domestic Engineer Fodder's Avatar
    That'll be the T-VSV being blocked off - gives constant boost in all gears instead of higher boost in 3rd / 4th / 5th. Pretty common when people are running a boost controller.
  3. #48
    Apr 2010
    canada
    idont have a boost controller...and u say it gives constant boost through all gears....why do i only hit 8 psi when i put itto the flor shouldnt i be abl;eto get higher then 8 psi in lowrpms....it will get to 16 by the timei hit 5500rpm
  4. #49
    Tasmania
    interesting, if you have blocked off tvsv then you should only be running about 8 all the time. You wont get boost low in the revs because turbos cant do that.
    1973 TA22
  5. #50
    In my far-from-expert opinion, I'd be checking the wastegate - sounds like 8psi is where it's set but it's creeping up from there.
  6. #51
    Tasmania
    they do creep if they have a real free flowing exhaust, but not that bad.
    1973 TA22
  1. 3SGTE Rwd Starter motor
    By SE86 in forum Tech and Conversions
    Last Post: 28-07-2010, 05:59 PM
  2. 3SGTE in AE82 Corolla
    By tai_180sx in forum Engine & Driveline Conversions
    Last Post: 02-05-2006, 07:58 PM
  3. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 03:03 PM
  4. 3SGTE cams into a 3SGE motor...Pros/Cons?
    By MFN-MAN in forum Tech and Conversions
    Last Post: 01-02-2006, 03:19 PM
  5. 3sge - 3sgte CAS - interchangable?
    Last Post: 20-12-2005, 08:15 PM
