Page 1 of 4 123 ... LastLast
Results 1 to 15 of 51
Thread: HELP!- 3SGTE diagnosis
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    Default HELP!- 3SGTE diagnosis
    hey all, ive got a weird litte problem, my turbo has been fubar'd for a while..actually its not that bad' still spools nicely and boosts fairly well, the oil seals are just gone..anyway long story short, at some point a few weeks ago, my gen 1 3sgte went from getting around 10ks a litre down to around 5-6 ks a litre in an instant, it didnt gradually happen...one tank saw me 420ks then the next tank saw me around 230 aswell as this my idle has dropped around 400 rpm, there are no power losses or any other symptoms other than the low idle and dog shit economy, has any1 go any ideas as to where to start looking?
    thanks in advance
    Default Re: HELP!- 3SGTE diagnosis
    i dont even know why i mention the turbo as it has been steadily declining for 3 months or so, and in the last few tanks of fuel it has actually been making alot more power under boost than usual and the turb is spooling a fair bit easier....i dunno im tired and stressed and rambelling
    GT4 Freak, and Conversion King Squid's Avatar
    Air leak? Can you hear the turbo more than normal? perhaps even hear the wastgate a bit?
    could it be your o2 sensor, has it been blowing alot of smoke latley.. i know you say your turbo seals which was cause it to smoke,but maybe is not the turbo!
    ~MR2 GT with a big arse turbo + a 3sgte built tonka tuff = lota Fun~
    the always broken 165 Carport Converter piggy's Avatar
    n.t
    his car dose blow a bit of smoke but is when he lets it idle for say about 1 or 2 min in the same place then when he takes of a little but constant line of smoke comes out of his exhust and dv and I are pretty sure that it is the seals in the turbo which are gone
    1974 TA22 Celica the new project
    2002 UZS171 Crown daily
    st165 white forged gen2 3sgte 264deg cams, 1000cc injectors, side facing plenum, GT30, CBR600 COP, 205 gbox, diff and calipers, haltech ecu,coilovers, 3'' exhaust, water meth injection 235AWKW @ 22psi 12.29@117MPH 1.885 60'
    yup as you say that sounds like turbo what colour is the smoke?
    n.t
    um i think it was a whiteish grey smoke i wasn't really paying attention to it sorry
    white at idsle is normally turbo seals as you say! The only thing i can think of is o2 and its running very very rich. It might be worth seeing if the ecu spits out any error codes!
    n.t
    im pretty sure it does off memory but i can't remember which ones they were that will have to be answered by dv
    hey all just got a chance to get on here, im pretty confident its a buggered 02 sensor, the turbo has been an issue for a while so it doesnt really explain the snap from great economy to shithouse economy in one tankload, as for error codes it doesnt spit anything out of the ordinary out, it smokes no more than usual, ie nothing on normal drivig...a puff of black when you snap second, and as piggy said it starts blowing a little bit of oil when it has been idleing for around 4-5 minutes, but that clears up after 30 seconds of driving. i stuck a bottle of injector cleaner through the last tank and that upped my economy to around normal for that tank load, but this next tank is back to only 120ks on the half mark :S, squid mine and piggys turbos are always BS loud..damn noisy ct26's. but anyway im really leaning towards the o2 sensor just shat itself, explains why one minute im getting 10ks to the litre and the next im getting little over 6 lol
    similar prob here, although not quite as bad ... orderd a new o2 sensor after doing the CEL diagnose, and all is good again ...
    ACA do the o2 sensor, its listed for the GT4 not the mr2 (if its a single wire version) and is about $70 from auto one.
    thanks man, ill definately check it out asap, cheers
    just thaught i'd update, a new oxy sensor has cleared everything up and baught my economy back to normal
    Rosewood
    well just to clear up why the oxy sensor died, it would more then likely be beacuse of the oil coming from the turbo seals which fouled the oxy sensor.
    Junior Member Grease Monkey omy's Avatar
    NT
    Reset the ecu too.
  1. 3SGTE Rwd Starter motor
    By SE86 in forum Tech and Conversions
    Last Post: 28-07-2010, 05:59 PM
  2. 3SGTE in AE82 Corolla
    By tai_180sx in forum Engine & Driveline Conversions
    Last Post: 02-05-2006, 07:58 PM
  3. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 03:03 PM
  4. 3SGTE cams into a 3SGE motor...Pros/Cons?
    By MFN-MAN in forum Tech and Conversions
    Last Post: 01-02-2006, 03:19 PM
  5. 3sge - 3sgte CAS - interchangable?
    Last Post: 20-12-2005, 08:15 PM
