Results 1 to 15 of 29
Thread: Dry Tare weight of a RA23
    Automotive wizard 1st year Apprentice
    Jul 2007
    Default Dry Tare weight of a RA23
    Can someone give the dry tare weight of an RA23! So i can do a few calculations for when i engineer my rotor! I think it is displayed on the rego papers! thanks
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Default Re: Dry Tare weight of a RA23
    RA28 1050Kg
    Jul 2007
    Yeah thanks but i think the weight of a RA28 and a RA23 are different!
    RA23 is lighter... IIRC it's about 950kg.
    seeyuzz
    river
    fairly sure that the ra23 is over the tonn mark as a turbo 1jz is legal in qld. Current rules are 2.5 cc forced induction per kg, so for 1jz turbo to be legal it must be over the 1000kg mark. From memory the ta22 is about the 960 mark and the 23 is heavier.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    I think the TA22 is 940kg?
    seeyuzz
    river
    The old One Backyard Mechanic
    Gidday
    Had a bit of a look around the net. Seems that the RA28 tips the scales at 1166kg (kerb weight) The RA23 comes in at 1071kg (see http://www.uniquecarsandparts.com.au...ifications.htm). The extra weight of the RA28 is put down to the extra metal in the back and the weight of the hatch and the glass. The TA22s seem to vary a bit as the model developed, with the very early coupe tipping the scales at 890 kg and then gaining about 90kg.
    Cheers Craig
    I find that info a tad suspicious.
    The RA25GT (the heaviest model in the RA25 range) tipped the scales at 1040kg.
    The RA28LT (Aussie spec) is 1050kg.
    I thought all coupes were under the 1000kg weight.
    I have the weights for the 73-75 TA/RA models... but it does not include the RA23/28.
    The GTV models were the heaviest... but only by about 5kg over the GT.
    seeyuzz
    river
    River
    Honestly I really don't know. Here's another different weight (for the RA23) of 1065kg but it is an auto http://www.uniquecarsandparts.com.au...ifications.htm
    for a RA23. They are obviously over 1000kg as the RTA allow you to put a 1J into them.
    Also http://www.uniquecarsandparts.com.au...ifications.htm seems to have a TA23 at 970.
    Well I give up.
    Why am i always a.. Domestic Engineer RAAAH23's Avatar
    Jul 2009
    New South Wales
    Well apparently on NSW RTA Rego forms its says:
    Tare Weight
    1040
    This is for an RA23 with Chassis Number RA23004286
    Also i have Rego papers somewhere of my TA23 if someone needs the weight of that aswell. =]
    Hope it helps
    Cheers, Alex
    - 1976 TA23 2T-GTE GT3076 ID1000cc E85 Haltech PS1000, W58, G Series Diff, B45 Simmons
    Well, it's the RTA weight you use - whether it is accurate or not - as they base the engine size paramaters (for upgrades) upon this figure. So, being 1040kg is good news for upgrading.
    IIRC the RTA now uses the weight of a vehicle that is the heaviest model in that range. So, they would pick the RA28 weight - as it is the heavier model - for the RA23.
    seeyuzz
    river
    so would that almost then include ta22's in the ra28 weight category?
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Nov 2009
    my ta22 says the tare weight is 950kg, i always thought it was 890kg
    Junior Member Backyard Mechanic rodi's Avatar
    Apr 2007
    In my QLD code of practice manual a RA23 is 1044kg RA28 is 1067kg so in qld a RA 23 is allowed 2.6l turbo or 3.13l na
    Quote Originally Posted by roadkill View Post
    No. Different models.
    Whereas the 28 is the liftback version of the 23 coupe - basically same model and floor pan etc.
    seeyuzz
    river
  1. weight distribution
    By mikie in forum Tech and Conversions
    Last Post: 05-08-2006, 09:16 PM
