Results 1 to 6 of 6
Thread: 3sge - 3sgte CAS - interchangable?
    Default 3sge - 3sgte CAS - interchangable?
    Hey, does anyone know if a 3SGE crank angle sensor can be used for a gen 3 3SGTE?
    Basically I just want to know if they are compatible, , are the wires and the operation the same and will the computer have a fit?
    The 3SGE CAS is not going on either a 3SGTE or a 3SGE, it's going on an 18RG using a Gen 3 3SGTE loom and computer.
    (\__/)
    (")_(")
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Default Re: 3sge - 3sgte CAS - interchangable?
    The 3S-GE dizzy setup is exactly the same electronicly as the 3S-GTE! The only difference between Gens is the way the pickups are mounted and possibly the connector!
    I'm actually using a GE dizzy on my GTE
    So it works then, excellent.
    Would you call it a purely "bolt up" conversion?
    That would be ideal.
    (\__/)
    (")_(")
    The alloy casing is exactly the same so it will bolt up no problem.
    Well that is very good news, thanks.
    (\__/)
    (")_(")
  1. Toyota's Interchangable Oddities.... (TIO#)
    Last Post: 08-06-2019, 02:24 PM
  2. ST162 3SGE Swap (Photo Diary)
    Last Post: 07-10-2007, 10:38 AM
  3. The 3sge oil burner has been pulled down and inspected.
    Last Post: 17-07-2007, 04:15 PM
