Page 72 of 85 FirstFirst ... 2262707172737482 ... LastLast
Results 1,066 to 1,080 of 1266
Thread: 3T GTE Tech
  1. #1066
    Jul 2009
    Default Re: 3T GTE Tech
    Advice needed. I have a t3 turbo now sitting on my garage floor.
    Install the new t3 or rebuild the ct20b?
    my old ride:
  2. #1067
    Hi Guys,
    Just placing my T series parts wish list here as well!
    http://www.toymods.org.au/forums/sho...34#post1494434
    Jason
  3. #1068
    Jul 2009
    Just putting it out there.
    Am chasing high mount manifold, turbo, dump pipe. Back to square one.
    Anyone?
  4. #1069
    Steeko,
    Why not go the same route as NME308 with a SR20 manifold and adapter plate and strap on a sr20 T28? I think NME308 has well proven the approach.
    Roger
  5. #1070
    Feb 2011
    south australia
    does anyone make stainless exhaust manifold gaskets for a 3t-gte???
    1985 ST141 TOYOTA CORONA SR 5SP MANUAL 2S-C
    1985 RT142 TOYOTA CORONA SR 5 SP MANUAL 22R-E
    1986 RT142 TOYOTA CORONA WAGON 5SP MANUAL 22R-E
    1984 TT142 TOYOTA CORONA GT-T 5SP MANUAL 3T-GTE
    1983 AT141 TOYOTA CORONA GT 5SP MANUAL 4AGE
  6. #1071
    Nov 2007
    Are you after something with both faces completely covered in S.S. or just after S.S. around the port? or a solid S.S. gasket?
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
  7. #1072
    Feb 2011
    south australia
    solid s.s. as im getting sick of having to keep replacing my exhaust manifold gasket no fun haveing to take everthing off all the time that means less time drive more time fixing i want it the other way round more time enjoying driving me car not fixing it. a friend sugested that i use what holden and ford use witch is stainless gasket but get it cut for a 3t-gte. or unless there is something avalable.
  8. #1073
    GT-T,
    I have never seen the genuine Toyota Gasket fail unless the manifold or head surface is warped. The aftermarket ones are shit tho.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  9. #1074
    Feb 2011
    south australia
    it could be that i got a bad batch as i got them from a swap meet 4 for $10. ill get the manifold tested to see if it is warped but still i need a gasket again.
  10. #1075
    Hey gt-t if the faces are straight I simply use silicon. If the faces are a bit warped I give the silicon 24hrs to dry before firing up...
    Jason
  11. #1076
    nuts Grease Monkey
    auckland
    Most of the oem exhaust manifolds ive measured seem to warp away from the head on #1 port.
    I don't see how silicon would last too long? might survive on the head flange if it's high temp stuff, but not on the turbo side.
    -Mark
    E2 + E7 fan
  12. #1077
    Quote Originally Posted by AE25 View Post
    You don't have to 'see' - all you need to know is that when I post stuff it is actually working for me under rather stressful conditions.
    Jason
  13. #1078
    Jul 2009
    3j tell me more about sr20 manifold..
    Does it line up to 3tgte ??
    my old ride:
  14. #1079
    Junior Member 1st year Apprentice mattlock's Avatar
    S.A
    Hey Jason, (yellowRolla) im still waiting for you to send me details on where to send you my 3TGTE long motor after our long and informative chat on the phone the other day where is you workshop JRM? i need to get a quote from a transport company to get my long awaited engine sent to you to get it started. please PM me your addy details
    Regards
    Matt from SA
  15. #1080
    Hi Steeko,
    Since I am currently running an SR20 topmount ebay stainless manifold and previously a factory cast SR20 manifold on my 3T I'll jump in!
    Port spacing is 'almost' identical between the SR20 and the 3T motors.
    The outside two holes on an SR20 manifold line up with the Toyota positions.
    A factory SR20 lowmount manifold fouls the engine mount and possibly the starter so flipping it for topmount is best.
    Either aftermarket topmount stainless or flipped factory SR20 manifold it is best to make a spacer/adapter plate due to larger port diameter of the SR20 item.
    It took me say 3 hours to make the adapter plate from 12mm mild steel with hand drill, die grinder, and thread tap (only for flipped factory mani).
    When mounting the stainless manifold I drilled and slotted the head flange to use the toyota pattern. SR20 uses 2 bolts per runner while toyota shares some.
    Jason
  1. 3T Versus 3T GTE conrods
    Last Post: 01-06-2007, 12:59 PM
  4. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
