Page 302 of 392 FirstFirst ... 202252292300301302303304312352 ... LastLast
Results 4,516 to 4,530 of 5875
  1. #4516
    Sep 2011
    i couldnt really find any good sources on the internet.
    Whats 0-100km/h on the 18rg? roughly
    1977 RA28/ P-plater
  2. #4517
    Quote Originally Posted by allrounder View Post
    Dropped from a plane, in a hilux, in a clubman?
    Stock in stock RA23, not quick.
    Jan 2011
    http://www.measurespeed.com/zero-to-...calculator.php
    Depends on what car you have it in, the engine (ie what version and what mods) and how you drive.
    FWIW, using a handheld stopwatch (passenger that is) my old 2.2L 18-rg, ra23 (40mm webers, 40 thou over pistons, extractors etc) about 7.5 seconds, so not as good as this calculator would have you believe.
    I refuse to believe my driving was the weak link.
  4. #4519
    Junior Member Backyard Mechanic leso's Avatar
    Quote Originally Posted by Taff View Post
    Is the orange beast on the road now?
    it is ready ... not sure if i am ready for the awesome power
  5. #4520
    Aug 2009
    Quad throttle bodies for Weber DCOE pattern
    Found these on ebay
    http://www.ebay.com.au/itm/Throttle-...item27c9b12795
    Rgds, Willofan
  6. #4521
    Nov 2007
    Okay so I've been enjoying my celica too much recently, actually driving it around including regular trips to work and back, so apparently I'm over due for some bad luck. The 18RG has been running nice, apart from the slow lumpy idle that is slowly shaking the first muffler apart. So yesterday I get home and think I'll up the idle a little to smooth it out before the guts of the first muffler end up out the back of the exhaust. When I pop the bonnet I notice combined with the noise of the mufflers internals rattling and the exhaust hitting something under the car a nasty knocking sound coming from the front of the engine. I had been hearing this knocking while sitting idling but had assumed (the mother of all F/ups) that it was just the exhaust hitting whatever it has been hitting under the car. From the brief amount of time I had to poke around I determined the noise to be somewhere at the front of the engine possibly behind the timing chain cover. Anyone have any thoughts on what might be causing this? I'm hoping it's as simple as a loose chain guide but I'm beginning to fear much worse.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
  7. #4522
    could be a few things and depends on the rattle. Could be worn/stretched chain, could be low oil pressure not tensioning the chain properly (which could just be using the wrong oil for the conditions) you may have a worn chain pad or even broken/missing. And this could be on either of the chains too. You may just need to adjust the upper chain tensioner as well. Check the green bible for the specs and how to do it.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  8. #4523
    Chains is the easy one to blame. If the rattle disappears when you rev up a touch, then try tightening the upper tensioner just a small amount. If the rattle improves from this, then keep going until it stops, or reduces to an acceptable level.
  9. #4524
    Top End
    OOOOh on the subject of chains
    since TRD/HKS gear drives are non exsistant and the few people who have them are not willing to give them up for the purpose of making copies I HAVE AN IDEA that should work in theory
    this is a pic of the HKS GD for a 2tg the TRD one for 18rg looks similar
    now just to add both these systems 2tg + 18rg drive an AUX shaft of the crank at 1/4 speed to run a dizzy
    so other than crank and aux shaft diameters is there any reason one could NOT convert this 2tg gear drive to run on an 18RG
    said gear drive
    http://www.brdracing.com/2tc_3tc_timing_componets.htm
    and the next bit seems easy enough
    make one of these
    from one of these or similar
    http://www.ebay.com/itm/ws/eBayISAPI...m=170852888617
    anyone on here TOY-ed with the idea
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
  10. #4525
    Nov 2007
    Unfortunately it's not really what I remember timing chain rattle to be. It's definately more of a knock. I've parked her for the moment until I can investigate more. The one thing I did do was pull the #1 plug lead to see if the knock went away. It didn't. However the engine also didn't miss a beat. I then reinstalled #1 plug lead and pulled #2. The engine died almost straight away. At this point I went away concerned and curious. Concerned #1 cylinder is rooted and curious as to whether I have only ever experienced 75% of the awsomeness of the 18RG.
    Next step is to get an appropriate attachment for the compression tester and begin investigating.
    Glen
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
  11. #4526
    hI,
    next step is check oil for water and water for oil....... Can you get some video/audio for us to see/hear?
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  12. #4527
    Top End
    number one bearing is decieding to go back to its basic elements they dont just do this under hard cornering and acc. and oil pump cavitation they do this when your oil galleries gunck up and cant provide enough lube to pot 1 and occasionally 2 but mostly number 1 thats just from personal experience for us on several motors nearly always number one bearing that failed through oil starvation issues
  13. #4528
    Nov 2007
    I'm actually in the process of installing an idiot light to complement the standard oil pressure gauge. Received the globe holder to fit into the dash the end of last week. Oil pressure has always been at the top end although the standard pressure sensors are always slow to respond to change. If it is a bearing, might have to try and flush the oil system and make sure oil is getting everywhere it should be. And maybe invest in an extra high volume pump to maintain the pressure at idle.
    Glen.
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
  14. #4529
    Top End
    an accusump setup will going in on my 18RG
    when you find an of the shelf oil pump solution let us all know 100s of people are after them LOL
  15. #4530
    Junior Member Grease Monkey MorgzMods's Avatar
    Aug 2011
    I've posted a thread up asking for some advice about an 18r-g + 18r-c options
    If anybody can offer some info the thread is here
    Thanks
