Page 352 of 392 FirstFirst ... 252302342350351352353354362 ... LastLast
Results 5,266 to 5,280 of 5875
  1. #5266
    i lubed everything up when i assembled it about 2 years ago. it wont turn in either direction. i was just about to fill it with oil and crank it through to avoid damage when this happened.
  2. #5267
    Quote Originally Posted by lilcrash View Post
    Doesn't sound great mate. I'd be removing the clutch and flywheel just to make sure nothing's jamming it up there, but if you suspect that it's seized then i'd be taking it very seriously. I'd be taking the plugs out to have a look at the bores with a boroscope and maybe taking the cam cover off and inspecting the cams and chains just to be safe. If you can't get a boroscope then you might have to take the sump and have a squiz from underneath.
    Honestly as soon as my engines are fully assembled on the stand they get a full fill of oil and turned over by hand until they're primed, my current 18R-G gets turned over for 5 minutes or so once every few weeks just to keep the good stuff circulating. I don't understand why people leave motors dry.
  3. #5268
    I got it turning. It was only left dry as I didnt have an oil filter. Or a car to put it in. It was being used as a coffee table.
  4. #5269
    Good to hear matey, nothing worse than having to pull down a freshly built motor.
  5. #5270
    Now my only problem is working out what one of these 3 bottles of run in oil is new. Anyone in here know how to fix an odometer?
  6. #5271
    Sydney N.S.W
    Well other than an engine which wont keep running, i have been dealt with another motivation blow.
    Due to the windy days of late, my perfectly good black bonnet was blown from its storage place and has now a damaged/dented/scratched bonnet bulge.
    thats killed me now.
    more steps back. errrrr
  7. #5272
    Sorry for the stupid question again, is there supposed to be a clip holding the clutch fork to the throw out bearing? I just got it all bolted together and just realized I may have forgotten if it's supposed to have a clip in it.
  8. #5273
    Yup sure does....otherwise it won't pull back with the clutch fork and will be rattling around loose on the input shaft..the 'ears' on the bearing carrier won't line up with the fork arms and i suspect something nasty will result...at best you probably won't get full clutch release, at worst a very rapidly spinning pressure plate may meet something it's not supposed to!!
    Shit. Thank you
  10. #5275
    ok ive found one clip, am i supposed to have 2?
  11. #5276
    Yep, one on each side of the bearing.
  12. #5277
    Argh. I'm so not suppose to put the 18rg in my car, everything is going wrong. Of the 4 gearboxes here I've got 1 clip. Not sure how but yep although I only found 3 clutch forks and 2 throw out bearing carriers and I found this one clip in a w57 bellhousing on the floor.
    Found them online. $4 for the clip and $84 postage.
  13. #5278
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    you can still get em genuine from toyota unfortunately i dont have the pn for you but they are definately cheaper than $88 total
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
  14. #5279
    Yeah I found them on toyodiy, $4 each. If I can't find one at the wrecker il order them on Monday. Has anyone got a picture of the 2 different extractors? I'm not sure if I have celica or corona style.
  15. #5280
    Was that postage cost with Toyota or Amayama?
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
