Re GEARS.
The lower gears are all 18RC 8RB
The upper gears can be bolted onto early 210 camshafts and are from the 8RB 18RC camshaft. 3 bolts and a Dowell.
All Dowelled gears off the Yamaha head later series are a different matter they actually fit on the opposite way to the bolted gears off the single cam.
I am sure it is possible to find old 210 type camshafts aftermarket or you drill them out and use the single bolt and one dowell in the later camshaft.
I am told you can get two 8RB or 18RC cams and grind off the unwanted lobes leaving the inlet lobes and exhaust lobes and they match up, dont know if this is an old wives tale.
The lower chain guide although smaller from the 18R will fit across the top and guide the twin cam chain ok.
