2tg thermo housing is passenger side is it not.
that makes that a 18RG
18RGEU has DOHC embossing I have since been told thanks to all.
FYI at least 6 18RG engines in or out of cars on Ebay at this time. Trying to find if any are early. One possibly with the tell tale "water leaking out of back of head gasket" Buyer beware that will be stripped 12MM fine thread metric for sure which is what brought the Toyota headed high compression engine to a terminal end.
At 9.7:1 my experience in high speed touring rally use was a succession of blown header tanks on the radiator necessitating a smaller crankshaft pully which caused less water flow and overheating in the rear of the head causing head gasket failure, rusting of fine pitch metric head bolt thread and ultimately thread failure.
it is highly unlikely anyone in Australia ever saw a Toyota headed 9.7 engine.
None ever came into API Springvale as I checked for months in 1980.
Rivers Celica might have one. My Corona had one which was removed and a Yamaha head 1975 model was fitted in its place.
One sad entry in my much thumbed 18RG engine repair manual is dated 1979 170/155/170/170.
rear cylinder leaked down like a seize.rear firewall covered in white bars leak..
1968 RT40S Corona 1600S series II (restore in progress)
1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
2012 ZN-6 86GT (shed find 5000 km in 6 years)
Black Betty >HERE!<
(\__/)
I guess so. 18RGEU ...... had DOHC embossed and the oil filler is in that place on the 18RG.
Thanks all![]()
beg to differ ... im sure ive seen "DOHC" 18RG cam covers before.
Actually I think Ibz 'DQIKST' on here bought one from Lambolica.
Black Betty >HERE!<
(\__/)
I am certain that one of my old 18RG's had the DOHC cast in the cam cover.
I also think (not much certainty with this one), that the oil filler was in two different locations across the 18RG range.
2TG
As TA-022 said the 2TG thermo housing is on the passengers side of the car. Therefore, it is an 18RG.
And just for note the 18RG did have a DOHC cam cover available, I believe it was on the later model 18RGEU's
18RGEU
2TGEU
Note the location of the breather hole in both.
Finally, check out the stud pattern on both covers, even if they were the same length and width, they're not going to inter-change.
Correct, and i think i have one sitting around the place too. The "DOHC" embossed cam cover is from the 18R-GEU (RA63) engine.Originally Posted by TA-022
Ibz - i think you are going to need new rings mate.
I'm going to doubt this one, simply because i've only ever seen one type/location of oil filter mount on every 18R-G that i've ever seen (and thats a lot)Originally Posted by YelloRolla
He said oil filler, ie the cap on the cam coverOriginally Posted by The Witzl
This is my engine:
18R-G in a RA63. It came originally in this car.
More pics in my web page.
Oil filler not filter, and I am correct, they were at least available with the filler on the driver's side at the rear and the passenger's side at the rear.Originally Posted by The Witzl
Aww comon guys, I am borderline down syndrome!Originally Posted by YelloRolla
and you are correct jason....
but you are also gay, with aids
borderline? your only kidding yourself with that 1![]()
Black Betty >HERE!<
(\__/)
yes i have the later model cam cover with DOHC on passenger side and oil filler on drivers side
the one currently on engine has nothing and oil filler on passenger side
DQIKST
and Karl i think it is my rings was suppose to do a wet compression test today but not going to get around to that.
ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph![]()
NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES![]()
whats the gee-ooo with every one having chicks in there avatars
1980RIP NATHAN BRETT DEAN2007,
I found something interesting the other day while looking at my new block.
The 18RGEUs that came with the two bolt oil pumps have an extra pair of engine mount holes. It appears that the rearmost hole from earlier blocks is shared, while another, more rearward hole has been added.
I reckon this might just make it easier to stick it into some cars with different cross members.
It would also help people identify if they have a two or three bolt oil pump, not that it really matters.
All I need now is to find the most suitable place for a turbo oil drain.
(\__/)
(")_(")
