Page 27 of 392 FirstFirst ... 1725262728293777127 ... LastLast
Results 391 to 405 of 5875
  1. #391
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Default Time Out
    Ediited for sapece
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
  2. #392
    Default The Natural progression.
    IN 1983: REX imported this engine and could not figure it out.
    it came from an ST142 GTT Corona.
    I took it back to Hamilton and made it work.
    So whilst the old school were frigging around making 18RGEU's go on 42mm solex.
    we moved on and made this 160 PS rocket go on EFI
    What sort of car did we put it into??
    ANYONE GUESS?
    You are looking at the first 3TGTE imported into Australia for an RAC Rally car in January 1984.
    UMM that is 22 years ago.
    The car is featured in Turbo Australia Issue 9 with a Ford Laser Turbo on the front cover.
    And a turbo datsun 240 Z inside.
    Tyres were NCT Steels HR65.
    daihatsu Charade 3CY turbo on page 26.
    and the new RX7 and EA falcons were advertised.
    ITS ALL BEEN DONE BEFORE GENTS!
  3. #393
    Default A Hint What Car Is It?
    Editted for sapce
  4. #394
    Steve - i just wanted to bring back into discussion what you posted earlier about using the 18R-C chain tensioner in the 18R-G.....
    was this the no.1 or no.2 chain tensioner? (ie. for the upper or lower chain?)
    ... reason i ask, my no.2 tensioner is spewing oil and shit all over the intake side of my engine bay, and the only spares i have are one broken one (thanks to stupid force and a shifting spanner) and another leaking one.
    Anybody had any luck just replacing the O-ring in the no.2 tensioner???
    ... pics coming soon to explian.
  5. #395
    I have second hand bits from upper and lower.
    is your upper or lower stuffed?
    The upper is driven by a plunger that screws into the left side (looking aft) of the head.
    I have a spare one of those and a spare rocker thngie.
    I also have a source in Adelaide of some new chains so how urgent is it and where is oil coming from?
    http://cgi.ebay.com.au/ws/eBayISAPI....MEWA%3AIT&rd=1
  6. #396
    no.2 chain tensioner is the one for the upper chain (see my dodgy mspaint diagram back on page 3or4or5, cant remember which now).
    Oil is coming out of the backstroke plunger and all around, very typical of a dead o-ring.
    will post more later, must fly to try and find new o-ring.
  7. #397
    Yeah it will be aan oring along the shaft take care in undoing it, unlock lock nut first dont try to undo from the end nut section or the brass sinter will split.
  8. #398
    well here's what i found when i opened the bonnet....
    so i checked my spare no.2 tensioners. Here is what they look like when disassembled.
    Be very careful undoing them!!
    Once you have removed the circlip locking the plunger in place, slowly remove the plunger vertically downwards (take it out from underneath the body) to try and retain the spring and wee teeny tiny oil control ball and cup assembly that is inside it.... if this falls out it's a BIG BIG PAIN to put it back in properly.
    Then push the shaft out the bottom slowly, and it's now disassembled enough for you to see the FUBAR o-ring.
    p.s. o-ring will have to wait until tomorrow now.
  9. #399
    Here it is
    Lower tensioner and guide (eBay item) $41
    Top and bottom chain:
    Standard type (as listed on eBay) $55
    Performance type $140
    Gears X 5 performance $210
    Top guide genuine $65
    Slipper guide genuine $240 (this is the last one I can get please let me know ASAP if you don't want it as I have 2 other people interested)
    Fixed guide no longer available.
    Postage would $15 registered plus extra insurance if required.
    Last edited by RT104GT; 21-09-2006 at 11:33 AM. Reason: Information received about chains in Adelaide.
  10. #400
    RT104GT,
    Im running EFI, so i have an electric fuel pump and surge tank system in the back - hence the dodgy homemade blanking plate for the mechanical pump location.
    Also with the chain tensioner no.2, i'm yet to get to CBC to find a suitable O-ring, but I will post the info up as soon as i have found a replacement.
    Steve!!!!
    i dont know if i've posted this question already... but i'm keen to find out details about the chain guides/vibration dampeners that you were chasing down. (not the tensioners, the slipper guides)
    I remember you posting a while back that some place was looking at remanufacturing them, which is quite important considering that both the two long curved slipper/dampener/guides for the upper timing chain are discontinued and out of stock in japan.
    (part numbers 13559-88270 and 13563-88250, in pic below the two red curvy guides)
    This is going to become pretty important for a LOT of 18R-G guys out there pretty soon, because these are the two hardest wearing guides of the lot!
    EDIT - found the post:
    Quote Originally Posted by SteveM
    I've heard that a guy in Adelaide is getting some custom 18RG guides made up, full set, 100 items of each guide.
    I will keep an ear to the group and a wallet full of cash and I'll see how I go. I only need the timing chain tensioner slipper, or, slipper C as it is sometimes called.
  11. #401
    Forum Member 1st year Apprentice pwrn's Avatar
    Quote Originally Posted by Screamn_Sleeka
    In the first post it says that the early heads are "rumoured to have smaller valves, and definitely having smaller ports", is it worth while to post up all the different sizes? I could only do it for 270's, but its pretty useful information, maybe when its all collected it could be added to the first post.
    i remember i had extractors (18rcturbo has them now) that i took off a 230 block, the 253 exhaust gasket matched the ports on the extractors
  12. #402
    Just got quoted about $240 for the curved and $110 for top from Adelaide.
    Do you want the guys name.
    OEM
  13. #403
    What about USA? NZ EUROPE?
  14. #404
    RT104GT,
    I am chasing up a David WOng who offered me some guides from Adelaide.
  15. #405
    I am running 10W-60 oil for older cars a recent addition and my timing chain noise is down to nothing. But I have run out of tensioner adjustment. Head went back on at 140,000 about 100,000 ago still that chain and guides.
