Page 196 of 392 FirstFirst ... 96146186194195196197198206246296 ... LastLast
Results 2,926 to 2,940 of 5875
  1. #2926
    Yes yes I can see performance wholesale taking a photo for me
    Now - RA23-WRX
  2. #2927
    Cometic have a picture of it on their website.. shame my headgasket is 30 minutes away to check it!
    Any one got one about and can compare to this picture?
    I have emailed the USA to ask if it suits the twin cam head or single cam.. will see what they say.
    Now - RA23-WRX
  3. #2928
    Going by the ACL drawings of the gasket it seems to be a 18RG one. (pics attached)
  4. #2929
    Awesomeness. The Cometic website list their one at US$85, which is a whole world better than the $255 Kameari one when I don't need the benefits of MLS.
    Will let you all know how I go.
    Now - RA23-WRX
  5. #2930
    Will also look into the Cometic for 18R-GTE use... as the stock toyota gasket is purportedly good for ~20psi. Will see how the vibe is for using a Compressed Fibre Metal reinforced (OEM style) gasket for my intended use (~16psi max)
  6. #2931
    As a separate note,
    In the coming weeks/months I will be purchasing a full gasket kit (again), which will come with a good quality head gasket that I can't use. So if anyone is after an 18R-G head gasket for a standard or close to bore size in the near future, then let me know as I would hate for it to sit in a corner and gather dust. At a minimum, if you are after one in a month or so, then let me know before you go purchasing one at full retail price.
  7. #2932
    im using the stock 18R-GEU head gasket for my 18RGTE.... i think it will see more than 20psi (when it ever gets finished)
    however i have an o-ringed head, which helps.
    The stock toyota gasket actually looks really good quality, and was dirt cheap too - $55.
  8. #2933
    Last night I head back from Cometic and its confirmed that the Cometic one is an 18RG one, and suits the 92mm piston.
    Will get one ordered pronto
    Now - RA23-WRX
  9. #2934
    Quote Originally Posted by o_man_ra23 View Post
    Stock gasket saw up to 30psi on mine with no issues....22psi on a regular basis Head bolts on the other hand
    I have ARP Mitsubishi studs on the way to take care of the head bolt issue... looks like Cometic is a viable alternative to the heavily priced Kameari item...
  11. #2936
    Quote Originally Posted by The Witzl View Post
    Same here. I'm using the stocker and it's good for some decent power.
    seeyuzz
    river
  12. #2937
    I didn't want any headaches when looking for head gaskets. I chose my bore size so that I can use standard head gaskets.
    (\__/)
    (")_(")
  13. #2938
    I chose my bore size so I could use big arse pistons
  14. #2939
    I worked on the same principle as oman.. just failed on thinking it all through lol.
    Cometic one is ordered, needs to be manufactured, which will take 5-7 days, and then it will wing its way to our shores.
    I will post a couple of photos when it arrives.
    Now - RA23-WRX
  15. #2940
    Sydney N.S.W
    Saw this on ebay. I was wandering if it's a cheap option for turboing the geu...
    Its supposed to be Universal, so there some items that need to be modified or added.
    what do you think.
    cheap kit at $550US freight $650 though.wow
    http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
    i asked if possible to fit to geu. reply was.
    Hello,
    This is universal.
    t3/t4 t04e SINGLE TURBO
    max tested psi: 35
    power efficiency: 400+ gain
    400+hp gain but thats at max psi.
    EXTRA PARTS SUCH AS MANIFOLD IS REQUIRED. READ
    NOTES BELOW THOROUGHLY!!
    NOTE :
    * Not all parts are bolt-on. Universal piping kit
    will need to be custom modified at an exhaust shop
    to adjust for the correct bends. *
    * Requires a down pipe which needs to be
    connected to existing exhaust. A custom adapter
    needs to be fabricated from a place such as an
    exhaust shop. *
    * Other parts you need or should get is Turbo
    Manifold, Boost Controller, Turbo Timer, and
    Engine/Fuel Management System. *
    * Professional Installation is Highly Recommended
    (No Instructions Included)!! *
    Thank you
