I am not sure how the 304/288 setup compares with your cams, when I bought the cams I was told they were used for rally car setup, I was after the 304/304 but was unable to obtain the second 304 cam and bought a 288 instead. The engine is a tg (1600) with a bascially stock bottom end except the steel flywheel. The jets on the carbs are as follows 190 main, 210 air jet,57.5 idle, 50 pump nozzle and accelerator pump on the #3 position (longer duration of fuel) add headers and a 2.5 inch exhaust and away you go esp at about 3300RPM. HTH Good Luck Be Safe
Greg
i may put this on hold and stick with the *****231 rg's
it's still attached to my last order.
