Page 14 of 21 FirstFirst ... 41213141516 ... LastLast
Results 196 to 210 of 301
Thread: Standard 1G-GTE Dyno.
  1. #196
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    Default 1g-gte
    Thats good, now i know exacty what i will be looking at getting cheers!
    JCMO: Yeah i was thinking about the turbosmart e-boost its about $700 retail fitted isnt it? I know its not the cheapest but it can do just about everything ive heard? How much more well would the results be on my stock twins running 1 bar as opposed to just a cheap boost tap? (powerwise) and is it possible for me to be able to make it go on boost a bit quicker? Because as you will know it has a bit of lag at the moment, so i would like to try and improve on that a bit if its possible?
    Cheers, James
  2. #197
    Default Re: Standard 1G-GTE Dyno.
    Was a while ago when I bought mine. Most retailed it for more than $700 for the unit alone. I paid $650 and fitted it myself, pretty easy.
    It brings on boost faster, but also minimises the spike and can force the turbos to hold peak boost for longer.
  3. #198
    Out of curiosity, how can any boost controller bring on boost quicker?
    I would expect even the best controllers can only control boost after the wastegate opens, so unless the gate is being opened too early (like before the turbo has spooled up) then there's nothing you can go with the contol to spool up quicker.
    I can see how it would avoid spikes (assuming the vaccum/boost lines aren't spaghetti'd everywhere) and also allow a higher peak boost by bleeding, but I can't understand how it can bring on boost quicker
    But I'd love to know how
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  4. #199
    The wastegate in an ideal world would only open when it got to the preset point, but poor design and/or age allow it to creep open prematurely. Because the boost controller actually sits between the compressor and the wastegate, it can actually block all the air to the wastegate. Eliminating the creep is how they bring it on faster.
  5. #200
    And is that creep at low RPM actually noticable on a good condition engine? Or only on old junkers?
    As the wastegate solenoid gets older it would actually take more boost to open it, so it must be losing the tension of the wastegate spring over time that allows it to open early?
    Current rides...
    2) White RA25ST
  6. #201
    Depends on the wastegate, all will have it to some point. The further you move boost pressure from the spring pressure the worse it gets too, which is the beauty of an EBC.
  7. #202
    cool... I see.
    Effectively you are making the wastage more like a switch than a valve
    A good gate solenoid *should* act like a switch, but doesn't seem to.
    Current rides...
    2) White RA25ST
  8. #203
    Quote Originally Posted by timbosaurus
    cool... I see.
    All wastegates open over a range of pressure and so its normal function for them to creep long before you get to the desired boost level. A good EBC prevents that as already explained. The concept that a Wastegate actuator works like a switch at a given boost is just not realistic.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  9. #204
    Jun 2007
    Dunedin
    Sweet as, well it looks like i will have to get a ebc then! Cheers for the comments.
    Another thing ive been thinking about is how much more power i can expect roughly
    with all those things i said i have done to the engine since my last run + also a 3inch exhaust and ebc running 1bar?
    I would be happy with around 140kws?
  10. #205
    No, all wastegates have a seat pressure or spring load holding them closed. and another pressure where they are fully open. Inbetween is where the gate starts to creep open. Depending on the type of controller, you can minimise this difference.
  11. #206
    Jun 2007
    Dunedin
    Quote Originally Posted by Gttwinturbomk3
    Does this sound reasonable?
  12. #207
    If you have a Gen3 1GGTE, then yes, thats a reasonable figure.
  13. #208
    Jun 2007
    Dunedin
    Quote Originally Posted by JustCallMeOrlando
    No its a Gen2 1986model.
    Say 130kws would be more realistic to expect then?
  14. #209
    Yeah, should get that easy. It's just better to hope for the low side and be happy when it beats it
  15. #210
    Just an interest question here, how often do you guys check and adjust the timing belt tension on your 1G's?
  1. *** Dyno Day History Lesson ***
    Last Post: 09-04-2013, 09:50 AM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 01:32 PM
  3. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 11:46 PM
  4. std altezza 3sge on chassis dyno
    By Celica RA45 in forum Tech and Conversions
    Last Post: 29-12-2005, 01:06 AM
