Page 10 of 13 FirstFirst ... 89101112 ... LastLast
Results 136 to 150 of 184
Thread: Pics of S13 susp into AE86 and RA23 fitment
  1. #136
    Default Re: Pics of S13 susp into AE86 and RA23 fitment
    Quote Originally Posted by TA-022
    h i think Toy77? ordered in S13 techno strut tops on this sizing assumption.
    apparently fitted with no dramas other that centre bearing height.
    but bolt pattern wise were dirrect fit from what i hear.
    T3 adjustable strut tops arrive with 2mm smaller studs than the stock TA/RA Celica's
    cheers Chuck.
    MS51Crown Coupe,
  2. #137
    so have you guys got a direct fit kit sorted for the 23/28s?
    what LCA?
    what STRUT s13/14?.....14 mentioned above,
    what HUB?
    what BALL JOINT?.....
    ive read through the whole thread, but cant work out what's what...too much talk about ae86's confusing me ;P
    cheers blake
  3. #138
    Chief Mentallurkist Grease Monkey
    Very interested in doing this to the 28.
    After digging a little…
    From Page 4
    From Measurements a S13 Balljoint will press into a GH Sigma LCA, have ball joint and LCA but havent pressed together yet.
    GH Sigma LCA +30mm compare to RA23 LCA, front link and sway bolts line up.
    S13 Spindle -20mm compared to RA23 Spindle (ball joint to Wheel mount flange with brake rotor in place)
    From Page 5
    S14 LCAs are about 15-20mm longer than S13. Though S13 and S14 balljoint tapers are different.
    So S14 LCA with S14 5stud hubs is another way to go about it. S13 coilovers fit S14 hubs.
    That'd be a track increase of 60-70mm either side too. Sick, but may adversely affect some form of handling.
    And I have no idea about bump steer.
    So, if Im correct, a (possibly overly complex) combo to use on a RA28 would be –
    A GH Sigma LCA (To get away from the 60-70mm track increase) with a
    S13 Ball joint with a
    S13 Hub with a
    S14 Coilover strut.
    And teh massiv brakes.
    Thoughts?
    New research?
    Flames for dragging up an old thread?
  4. #139
    but does a s13 balljoint fit into a signma LCA? i doubt it.
    you can however get magna balljoints into a sprinter LCA, i have done it but didnt use them in the car as the track was slightly narrower than standard.
  5. #140
    bumping this up again..
    someone had mentioned (recently?) that the offset between ball joint and tie rod end for AE86 steering arm is 16.2mm (offset when looking from front)
    has anyone measure that distance for the S13/S14 stuff?
    also, has anyone looked at the WGC34 RWD stagea front bits? they look similar to the S13/14 but not sure which yet.
    also, length of the steering arm, from ball joint to tir rod end, looking from side of car, for AE86 nonPS= 135mm, and PS =115mm, any ideas on lengths for S13/14?
    heya Dan,
    any followup on this?
    Quote Originally Posted by dan05k
    not shure if anyone has mentioned this before, but s13 struts go into a ke 20 REALLY easy! just getting pics now,
    (dan your PM box is full )
  6. #141
    sus-023 Backyard Mechanic Slidin23's Avatar
    Apr 2007
    123 fake street s.a.
    hey i am doin this convo right now on an ra23 but have no idea what lca to use i have the s13 coilover and the stub axel set up but am really confused as to what lca to use
    help
    p.s this car is goin to be used as a track drift car so dont care about bump steer or ride height but would like as much lock as possible and as much track as possible
  7. #142
    so use s13 lca?
  8. #143
    I will be doing this conversion also in the near future, and I'm thinking that I'll use the MX62 LCA, but it'll come down to trial and error as I have a KE70 R&P setup in mine also and I'm not sure if using the AW11 rack end will work with that like it does on the AE86 setups...
    ([][][]II--LT--II[][][])
  9. #144
    if you are using a ke70 rack and pinion does that mean you are using the whole crossmember?
    if you are then just use S13 lca, mx83 inner rack ends and bluebird tie rod ends. too easy!
  10. #145
    Won't that affect the akerman angle on an RA28?
  11. #146
    oh btw if your doing this in an 86 or 23/28 make sure you use an s14 strut not s13.
    the s13 strut is about 50mm shorter than you need and doesn't allow enough droop in the suspension which really sucks when your trying to pull a car up on a bumpy road (you feel like a rock skimming over a pond).
    linden
    Will using an S14 Coilover change any of the other parts that are needed for this conversion? (Ie. Hubs, etc?)
  12. #147
    Forum Sponsor Conversion King
    Dec 2006
    14mm bolts in the uprights, so either drill out the upright to suit or use some thin spacers in the struts (i prefer the drilled option)
    linden
  13. #148
    Dec 2006
    and just to confirm my thoughts on this suspension setup in any toyota ever made = shitest idea ever.
    i did it to my own car once and could never fix the shithouse handling it caused, properly built coilovers + decent brakes is a much better idea.
  14. #149
    I think I lost you with the uprights part, but as long as it will work, then purchase some new coils I shall be doing!
    The reasons I wan't to do this is that it would be an improvement in suspension (not huge, but still improved) and the R32 and R33 Brake Setups bolt up without the need for expensive adapeters/machining that costs almost as much as the coilovers themselves...
  15. #150
    Apr 2007
    so sigma lca arms dont work????
  1. Further adding to Article - Putting S13 susp. into AE86.
    By Sprinter-Saurus in forum Tech and Conversions
    Last Post: 27-01-2006, 09:42 PM
  2. Replies: 1
  3. wheel fitment ae86
    Last Post: 18-01-2006, 04:35 PM
  4. Replies: 112
    Last Post: 05-01-2006, 04:01 PM
