Also, its not the spline length which makes them less usable, its the fact that they are 4x100 not 4x114.3
I'm going to refute the above statement - There is no such thing as a "tough as guts" T series diff or axle.Originally Posted by ae86drift
Compare the kouki(??) T series axles to that of an F series or G series - you will see![]()
...... butt scratcher?!
hahah very funny karlOriginally Posted by The Witzl
its the toughest t series there is though.
and takai point taken.
is there no way to change it?
Garth - 100% AE86 Addict
AE86 - Levin & Trueno - The Legends Live On!
'AE86' - Toyota Sprinter Trueno GTV
"It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
Sorry dudes! I mixed up the rare/common ratio bit. Will edit my post to correct it.
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
The Aussie build MS55 and MS65 had Holden diffs, not Borg Warner. Holden actually built them for AMI under contract. They were a 3.9 ratio course spine diff and still had "Holden" stamped into various parts. Basically the same assembly as HT Holden except for ratio. Any Holden banjo centre will fit as long as you use course spline star gears. These are the models that have the much sort after front hubs for the Supra five stud conversion.
Never seen a Crown with a Borg Warner diff??
BTW AMI stands for Australian Motor Industry they assembled some Crowns, Coronas and Corollas. They even assembled Rover vehicles.
They pretty much took a good car and ruined it "for Australian conditions".
Shane.
Originally Posted by river
i put the ratios in the toyota form and plan to paste this into the file;
Read the Axle Code from the vehicle indentification plate.
first digit: ring gear diameter
A 138mm
B 145mm
C 6.25"
D 6.62"
E 7.1"
F 7.5"
G 8"
H 9"
J 9.25"
K 9.5"
L 10.5"
M 12.5"
N 13.5"
P 14"
Q 12"
R 162mm
S 6.38"
T 6.7"
U 6"
V 10.6"
W 15.5"
X 142mm
Y 158mm
Z 202mm
- no ring gear = FWD
Second, third digits: gear ratio
01 3.30
02 3.36
03 3.545
04 3.556
05 3.70
06 3.889
07 3.90
08 4.111
09 4.222
10 4.375
11 4.444
12 4.625
13 4.79
14 4.875
15 5.125
16 5.286
17 5.60
18 5.714
19 5.833
20 6.167
21 6.667
22 6.78
23 6.833
24 7.64
25 4.556
26 5.571
27 3.364
28 4.30
29 4.10
30 3.727
31 3.909
32 6.591 or 4.807
33 7.503 or 5.583
34 6.781 or 4.786
35 7.636 or 5.60
36 4.778
37 3.583
38 3.417
39 3.154
40 5.375
41 3.308
42 6.500
43 3.550
44 3.214
45 3.533
46 2.928
47 3.944
48 3.356
49 3.729
50 3.400
51 3.736
52 3.722
53 3.250
54 3.941
55 3.333
56 2.821
57 4.058
58 3.238
59 3.234
60 3.519
61 2.724
62 2.892
63 2.655
64 4.312
65 3.837
66 3.071
67 3.526
68 3.095
69 4.176
70 5.857
71 2.962
72 3.949
73 4.285
Fourth digit: no of pinions, ltd slip-yes/no
Code pinions ls
2 2 no
3 2 yes
4 4 no
5 4 yes
hello
done..........Originally Posted by gianttomato
yeh i found your post in the "f series diff ratio availability" thread. thats were that came fromOriginally Posted by Hen
changes made there also....
hello
<1973 TA22 manual had 4.1:1, D series 6.67" rear end
>=1973 TA22 manual had 4.1:1, T series 6.7" rear end
4.3:1 T differential was available in TA23 auto as an option only.
Every australian TE72 liftback (T-18) I've seen is 3.9:1.
theres the answer i wanted
cheers mate (+rep 4 u)
Originally Posted by SeptemberSquall
changes made![]()
hello
if u can break a T series with 67 fly wheel kw then i wouldn't call them strong at all !Originally Posted by The Witzl
Props for putting this info together mate ur gunna help out alot of ppl !
that a and b series stuff is incorrect
a series is 200mm crown wheel, b series is 220mm
im not sure how those numbers got so popular, or what they actually refer to!!
../delete/ban
tech moderator
the ratio / sizing info brettles here has been referring to is the chart available from the Toysport website.
Unfortunately this information doesnt hold for the "new style" gearbox / diff codes that Toyota has been using since the early 90's.... this includes the A series diffs now used in the Hilux and Supra.
Basically - if it's 1990 or newer, disregard the chart above
Now, some use[less] info from Teh Witzl!
# RN2* Hilux = 1370mm width, will measure drum size tonight
# RN4*/YN4* Hilux = 1410mm width, unsure of drum size (i think 8"?)
# UZS131 Crown = G series, IRS, G474 code iirc, non-LSD
# AE71/KE70 = ghey bog warmer, 1410mm width, p00
# TE72 (aka T18) = T sereies, 3.9:1 ratio, open centre, 1410mm width
*****NOTE: AE71/KE70 driveline is BOLT IN replaceable with TE72 T-series gear (you need TE72 gbox, tailshaft and diff)
can anyone tell me the presise width of the MS112 diff.
so far ive read of 3 different disk-to-disk widths![]()
need to know if width will come close to the RA40 width.
hello
hello
