Results 1 to 8 of 8
Thread: 4AGZE Idle Issue
    Oct 2011
    Default 4AGZE Idle Issue
    OK - I've just converted my AW11 4AGZE back to standard and I'm having a PITA idle issue.
    If I start the car it revs quite high initially to about 2K, then drops and stalls. All within a few seconds.
    If I caress the throttle, I can stabilise it, but it hunts up and down quite abruptly - not like the coolant-not-purged hunt, this one is aggressive and I know the coolant has been purged ok.
    These are the things I have tried
    Completely different TB - with pre set TPS and different idle control valve
    Changed the ECU
    Change the O2 sensor
    Changed the AFM
    Changed the exhaust
    Checked and replaced all the vac lines
    put in new plugs
    changed the ig coil
    Nothing here makes any difference ..
    Temp is steady on 190F
    Any advice would be appreciated ....
    perth
    Default Re: 4AGZE Idle Issue
    got the abv connected still ? all the blue/brown solenoids working and plumbed correctly ?
    Oct 2011
    Yep - all the vac hoses appear to be correct ...
    One more thing - I do have slightly larger cams (256 deg Kelford) they are not aggressive by any means and I really don't think they would cause this issue, but I have mentioned anyway...
    Surely some one has had this type of issue before ... and fixed it ????
    perth
    id be looking at the different tb and idle control valve. the icv might not even be working.
    usually a 4agze with idle problems like the one you have is associated with installing a front mount cooler with longer pipes.
    but seeing as you dont have a fmic and different tb and icv, could point to that.
    Oct 2011
    Ive changed the tb including tps and icv completely without success. . What are the odds of having 2 faulty icv's? Can they be bought new?
    perth
    oh i thought you meant, a different tb from another model car.
    if its all stock. ecu and all. read the codes out.
    Nov 2011
    A lot of 4agzes have idle issues when u put them in rear wheel drive form like in a ae86
    And this is due to vac hoses and stuff being Mixtec around
    I've worked on these issues many years ago and some I could not get 100 percent
    But yours is standard form so maybe u have problem with hoses
    Also I doubt the idle motor will have enough opening on fuly open to get to 2000rpm
    So maybe your accelerator is sticky or the linkages or return screws
    Anyway I recon u have air leak that's making it goto 2000 rpm
    Try blocking air that feeds the idle motor and see if revs stay low
    Diserter Domestic Engineer
    vic
    I had a few idle problems which turned out to be the ECU but nothing as bad as you've described. Mine were all temp sensing related. I just replaced the ECU with the correct model number, which changed every year.
  1. 2t idle issue
    By matt_spitfire in forum Tech and Conversions
    Last Post: 08-09-2010, 05:25 PM
  2. High idle issue (2jz aristo)
    By woggin in forum Tech and Conversions
    Last Post: 21-02-2010, 12:09 PM
  3. Another 1GGTE idle issue
    By Rosie in forum Tech and Conversions
    Last Post: 18-08-2009, 12:00 PM
  4. 2JZGTE - Idle Issue
    By teamdrinkalot in forum Tech and Conversions
    Last Post: 30-03-2009, 07:14 PM
  5. 1/2JZ Alternator issue supply at idle
    By BMWTurbo in forum Tech and Conversions
    Last Post: 30-04-2007, 06:17 PM
