Results 1 to 5 of 5
Thread: Another 1GGTE idle issue
    Built not Bought Grease Monkey Rosie's Avatar
    Default Another 1GGTE idle issue
    G'day all, I have a 1 ggte that has issues at idle ( idles a bit then cuts out). At aroung 3G it stumbles and coughs a little. I have checked AFM, Alternator, ISCV, Wiring, Air leaks, and most things suggested within other posts and all seems well.
    Now I am only running a dump pipe at moment - is this the issue??, I havent played with turbos too much before and am unsure of the consequences of just running a dump. I have a surgey set up but no FPR ( not needed?).
    And my last thought is new plugs? The spark is good underload but they were a little fouled - so they were just cleaned up ( pretty sure they were iridium ones too. It is throwing fault code 12 up but fks me if I can find that little post anywhere, any help would be great. Cheers Rosie, 281G.
    Default Re: Another 1GGTE idle issue
    Black Betty >HERE!<
    (\__/)
    Default Re: Another 1GGTE idle issue - the saga continues.
    thanks for the codes, just pulled dizzy out and checked all wiring - 0.04 v(seems very low for a signal) out of each of the four wires, and it won't run with the plug disconnected - therefore it is working?
    Checked the starter signal circuit and there is 12V.
    just windering if someone has an idea of what sort of signal im looking 4 out of the dizzy.
    Also i have replaced the spark plugs (needed doing anyway), 456 seem good (firing deposits) but 123 are almost like they arent firing (Shiny new ish), I definitely have spark - injectors gone??
    Just one more for yas - i have 2 plugs off the TPS, one small one with 2 wires ( whats this for) cant find it on wiring diagram and also the larger plug with 6? wires on it, where does the yellow with red stripe go??
    Thanks for the help fellas
    should be higher voltage on signals like about 5volt.
    checked all relays?
    Black Betty >HERE!<
    (\__/)
    Jul 2009
    i'm having similar issues what did yours end up being??
    1985 RT142, 1GGTE,.now with t67-25g
    2009 Ford Fiesta LX
    1970 Ford Cortina MK2 440
  1. ISCV Cleaning (*May* solve poor/erratic idle)
    Last Post: 31-08-2009, 01:57 PM
  2. 1/2JZ Alternator issue supply at idle
    By BMWTurbo in forum Tech and Conversions
    Last Post: 30-04-2007, 07:17 PM
  3. 1ggte wont idle :(
    Last Post: 18-12-2006, 06:41 PM
  4. 1jz: unusual high idle on cold-start
    By bk_ in forum Tech and Conversions
    Last Post: 27-04-2006, 08:25 PM
  5. Replies: 9
    Last Post: 21-03-2006, 11:41 AM
