Results 61 to 69 of 69
Thread: Q's. re:4AGZE throttle body positioning/re-location
  1. #61
    Aug 2009
    Default Re: Q's. re:4AGZE throttle body positioning/re-location
    Hi Thanks,
    pretty good to hear other people's experiences.
    I've actually been thinking about the exhaust system lately..
    How to get the best flow but minimum noise.
    Not a huge fan of cannon mufflers at all...
  2. #62
    Sep 2009
    Big oval center mufflers and a 3" triple flow chambered rear
  3. #63
    Chiba
    ^^^ As above.
    I had a centre resonator put in my system (I asked for a muffler) and it buzzed and droned like a honda on vtec yo.
    I took it back and got them to stick a straight through muffler in it's place and the drone and buzz left to go haunt a civic somewhere and left the nice note of a GZE behind. I still get a tiny bit of a buzz on a cold engine and exhaust, but it's gone by the time I turn out at the end of my street.
    The trick is to fit the biggest straight through mufflers as you can, and as many as you can. Offset mufflers are good too, as the pipe is a bit longer due to being diagonal in the muffler (I have two offset mufflers in the rear of the Levin for the twin outlets).
  4. #64
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    Quote Originally Posted by Invid View Post
    x2
    I put the throttle after the SC on my 2TGEU (with SC14) and the noise the BOV makes when you are cruising at half throttle is a pain in the a$$. Currently moving the throttle to fix the problem.
    Atmospheric or plumback?
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
  5. #65
    Quote Originally Posted by Harreh View Post
    Plumb back, but the outlet is only about 15cm from the air filter so it's pretty much atmospheric. The pipe itself is only about 30cm long between the air filter and the SC so there wasn't much option to plumb it back further down.
  6. #66
    Aug 2009
    Quote Originally Posted by TERRA Operative View Post
    ^^^ As above.
    Terra - 'Twin offset muffler set-up..' Any pics of this?
  7. #67
    Chiba
    It's in the car so hard to take a photo, but it is basically two mufflers at the rear (twin outlets like a standard AE101 Levin) and the inlet and outlet of each muffler is not in line. That way the gas has to kink a little so the pressure wave hits the mesh and is absorbed by the packing material in the muffler a bit rather than travelling straight through.
    I'll see how it goes with the new 20v engine, and if it's too loud (it was ok with the GZE, but they are meant to have a bit of a bark), I'll be getting the single center muffler (straight through) swapped for two centre/offset mufflers so with the two offset ends together, they will form a 'chicane' of sorts.
    Four mufflers should keep the thing damn near silent, but being 2.5" straight through, they should still provide good flow.
  8. #68
    Aug 2009
    Yep I get what you mean by chicane.. so it makes a dog leg through the exhaust and would off-set the the resonant waves.
    Wasn't sure if you meant 2 exhausts in-line 1 before and 1 after the axle or a split set up.
    Google images......
    Aah... ok.. Like this:
    http://cdn.sulitstatic.com/images/20...9555ebb629.jpg
    I like the idea of twin exhausts..
    Might be a lot of work for my wagon though..
  9. #69
    Chiba
    Yeah, pretty much like that pic.
    The two mufflers forming the chicane will be up the front between the start of the little muffler and the bend before the split.
  1. Throttle body boring in Brisbane?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 08-02-2009, 10:32 AM
  2. KKR 90mm universal throttle body
    By dori dori in forum Otomoto
    Last Post: 07-02-2008, 09:27 AM
  3. Throttle body upgrade - stock engine?
    By blacktop in forum Tech and Conversions
    Last Post: 04-12-2007, 03:42 PM
