Page 6 of 8 FirstFirst ... 45678 LastLast
Results 76 to 90 of 109
Thread: Replace my SC12 with WHAT ?..to get a reliable 140-170 kw at the treads
  1. #76
    Jul 2009
    Default Re: Replace my SC12 with WHAT ?..to get a reliable 140-170 kw at the treads
    Shot an email off to Ogura just out of sake of curiosity. I still doubt they would be much cheaper then a twinscrew unit....
  2. #77
    Convictania
    why is it that these things are so expensive..? (the superchargers)
  3. #78
    Jul 2009
    The Opcon Autorotors from PSE are fairly cheap...
    Opcon-Autorotor SR3 3133 Supercharger - $1800
    http://www.pse.us/Products/Opcon-Aut...3-3133-New.htm
    Displacement: 1.33Litres/rev
    Max Flow: 276Litres/sec
    Max RPM: 13000rpm
    Weight: 13.1Kg
    Opcon-Autorotor SR3 3150 Supercharger - $1850
    http://www.pse.us/Products/Opcon-Aut...3-3150-New.htm
    Displacement: 1.50Litres/rev
    Max Flow: 293Litres/sec
    Max RPM: 13000rpm
    Weight: 14.5Kg
  4. #79
    Convictania
    that's far more reasonable than 4k.
  5. #80
    Chiba
    Ogura seem to only to OEM runs etc by the pallet, according to the email I got back.
  6. #81
    Not known unless ur blown Backyard Mechanic
    May 2007
    Kenne bell don't have a distributor in AUS as far I can tell.. You just have to email them.
    RonRob I think is in contact with them??
    I'm fairly sure he uses the AR1.33 unit for the setup he's trying to sell.
    I havn't found a map as of yet but this is a good article:
    http://www.kennebell.net/techinfo/ge...REWvsROOTS.pdf
  7. #82
    Jul 2009
    PSE also sell the Lynsholm units too...
    Lysholm 1200AX - $1850
    Model: LYS 1200 ax
    Displacement: 1.2 L/REV
    Max Flow: 250Litres/sec
    Weight: 8.0KG
    Max. speed: 15000RPM
    Lysholm 1600 A-AX - $1889
    Model: LYS 1600 A-AX
    Displacement: 1.6 L/REV
    Max Flow: 350Litres/sec
    Weight: 12.0KG
    Max. speed: 14000RPM
  8. #83
    Jul 2009
    Updated my supercharger calculator to flag a warning when the supercharger exceeds it's max flow instead of the psi warning I had previously.
    Anyone have any ideas on the maths to incorporate temperature into the calculator?
  9. #84
    Junior Member Too Much Toyota GUN METAL's Avatar
    Cool spread sheet !, let me give it a run
    Just got off the phone with Stewart Toyota, the list price for a brand spankas SC12 is wait for it...............
    $3060
    They are just checking availability and what spare parts are available
    In more news i have found a workshop keen to do the twinscew install, they recon a 6K budget should be ok, they have used sprintex charger a fair bit apparently........but not on a 4A, they are putting together a detailed price today....stay tuned.
    MY BELOVED AW11...Updated members ride thread>>>>http://www.toymods.net//forums/showt...=4584#post4584
    AW11s always welcome in my driveway !
  10. #85
    Do they even have new sc12's available? I highly doubt it
  11. #86
    Chiba
    I got a spreadsheet I was working on too. It's still a bit screwy, mainly in the intercooler calculations. I think the pulley ratio calc is a bit wrong too.
    http://www.jdmlevin.com/files/BlowerCalculator.xls
    If anyone can tidy up the calcs, feel free to do so.
  12. #87
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    I cant see a twinscrew setup costing so much, outside of pipework and bracketry not much else needs to be done really, you can use the existing idler setup, most of these units are the same dimensions roughly as the SC12
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
  13. #88
    Jul 2007
    i wouldnt pay 3 grand for an sc12 scott. that is heaps bad value for money if you want to stay supercharged get a twinscrew. otherwise go turbo. otherwise buy another used sc12 for like $200. you can go through 15 of them before you reach the cost of a new one!!!
  14. #89
    Harreh, i completely agree, this is my preffered option so far, but i think its a little more complicated than you think, especially with new intake, for throttle, newinlet manifold, all associated pipes and mounts. Its also a logistical nighmare to makr it fit.
    Trdee, dont worry man there is no way i am spending 3k on a new SC12, .............thats ridiculous !
  15. #90
    Chiba
    You can half rebuild the SC chargers as it is, rear bearings and oil seals. There's a coating business that reckons they can recoat the lobes for cheap too, I just gotta try them out first before I start recommending them.
    The only thing so far that can't be found is the front bearings, but I'm hunting them down to find something suitable.
  1. Differences between early and late SC12 superchargers?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 04-02-2010, 08:15 AM
  2. 1990 MX-83, replace with 7M or 1JZ
    By MX83-maybe in forum Tech and Conversions
    Last Post: 20-11-2007, 04:16 PM
  3. Small upgrade - SC12 onto 7AFE
    By birdie in forum Tech and Conversions
    Last Post: 18-10-2006, 10:32 PM
