Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 109
Thread: Replace my SC12 with WHAT ?..to get a reliable 140-170 kw at the treads
  1. #46
    Oct 2009
    Default Re: Replace my SC12 with WHAT ?..to get a reliable 140-170 kw at the treads
    There has to be a business near you Scott that would have experience in twin screw setups. I'm not too familiar with them, what is the hardest part of getting them to work? Brackets for it can't be too difficult to sort out..
  2. #47
    It's not a bandwagon till somebody does it.
    TooF isn't far away... plus watch this space...
  3. #48
    double post
  4. #49
    Jul 2007
    scott, regarding the install help... as you know i am always willing to lend a hand, although you might not want it. after all i helped install your current supercharger and look how short lived it has been
    seriously though between all the adub boys im sure we could get a turbo setup done properly and (relatively) cheaply. however i do agree with the charger idea. does ogura corp sell newer versions of the sc series past the sc12/14?
  5. #50
    nope, not really
    http://www.oguraclutch.co.jp/english...e_sc~type.html
    FHI make smaller ones for Kei cars..
    TRUST use Magnusson SC's, which look liek rebadged Eatons http://www.magnusonproducts.com/models.htm
    mazda one for abotu $2K http://page9.auctions.yahoo.co.jp/jp/auction/k121148395
    C's M45 kit for 4A? http://page7.auctions.yahoo.co.jp/jp/auction/g77395926
  6. #51
    Eaton only make the rotor assemblies, usually someone else makes the housings. Magnusson is one of those, they are OEM for GM from memory
  7. #52
    is that so? learn something new every day
  8. #53
    yeah, this is news to me as well...
  9. #54
    FFS! turbo's are not, i repeat NOT hard to put on a aw11. there is plenty of space etc.
    i'm sure you'll make the decision that suits you gun.
  10. #55
    Gearwhore. Backyard Mechanic
    Oct 2008
    Quote Originally Posted by feral4mr2 View Post
    I have been reading all the posts saying how hard it is, and was sort of confused. Once the oil filter is out of the way, there is literally shitloads of room in there...
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
  11. #56
    Convictania
    remote oil filter + td04 + steampipe mani ftw?? (obviously more to it)
    It's a real shame no-one fixes the chargers, if you're happy with it as it performs now.
  12. #57
    Throw it all in a ke30. That will make you shit every time you flog it. The tail just wants to get in front of the nose.
  13. #58
    Jul 2009
    Quote Originally Posted by Plonka View Post
    Pobably much easier to fit than the long Mazda/IHI twin screw SC.
    You can make the IHI Twinscrew about 5-6" shorter by removing the throttle body and funnel off the back of the unit. I was originally going to look at just making a it nearly bolt onto the head with a real small manifold (think of it as how they bolt blowers onto V6/V8's). I was only chasing low boost, so an intercooler was out the window.
    There is also one on Ebay for $500
    http://cgi.ebay.com.au/Macda-Eunos-8...13131001r20762
  14. #59
    Jul 2009
    Also found where you can buy the LYS120AX twinscrew (equiv to the IHI unit)
    http://www.hi-flow.com/HP8Super.htm
    Model: LYS 1200 ax
    Displacement: 1.2 L/REV
    Weight: 8.0KG
    Max. speed: 15000RPM
    Or even look at the Sprintrex twinscrews
    http://sprintex.com.au/Opcon_Autorotor.asp
    Sprintex S5-210
    Displacement: 0.94 Litres / 57 Cubic inches / revolution
    Max Air Flow: 210 Litres / second; 445 Cubic feet / min
    Max RPM (cont) 15,000
    Dimensions: Length: 318mm; Width: 185mm; Height: 128mm
    Drive extensions: 100mm, 150mm, 200mm
    Suited for: 300 HP / 225 kW Engines
    Sprintex S5-335
    Displacement: 1.46 Litres / 89 Cubic inches / revolution
    Max Air Flow: 335 Litres / second; 710 Cubic feet / min
    Dimensions: Length: 380mm; Width: 185mm; Height: 128mm
    Suited for: 500 HP / 375 kW Engines
    Just doing some quick plugs into my supercharger calculator, the Sprintrex S5-210 will be struggling to push more then 16psi all the way to red line (8000rpm) as it goes close to the max flow of the charger (8000rpm @ with 16psi requires 208L/sec, chargers limit is 210L/sec). You need a 1:1.78 belt drive, (160mm crank, 90mm supercharger)
    Using the Sprintrex S5-335 looks a lot better, 18psi @ 8000rpm is well within it's limits in flow and rpm. Only needa 1:1.25 belt drive (160mm crank, 128mm supercharger). The blower will only be ticking over at around 10000rpm, is only using 2/3rd of it's max flow so the intake temps should be reasonable and with such large pulleys for the belt drive, you should never have issues with belt slip or wearing belts out.
    Now I'm only banging out numbers here, they could be way off in real world terms, but they should definitely be better then an SC12 or SC14 in all regards except for price.... If anyone else comes up with different numbers or spots some problems, let me know, always keen to learn from my mistakes.
  15. #60
    no need for a Domestic Engineer finney's Avatar
    Ideally I'd go slightly bigger than a TD04L having had one on my old 4AGTE. from 6000 onwards it just went backwards (this may have been to do with the fact I was running 18psi which is just a tad overkill for a TD04L). Low/mid response was amazing though but when you're out on wakefield and not doing anything below 4500+ then you can afford to lose a bit of that low down response which to be honest was a little annoying as you'd be making instant boost on hill starts etc which was painful when in the wet during peak hour.
    I'd rather spend a bit more and source something like a VF34 which would have a bit more top end, yet still retail similar response since they're ball bearing. But if you're goign to be shelling out for a brand new turbo then 2560 etc.
    just my $0.02
    4AGTE SX - '4AGE' - 13.6 @ 103mph - 163fwkw @ 18psi - SOLD
    1998 JZX100 Tourer V - SOLD and now lives in radelaide
    1992 GTI - SOLD
  1. Differences between early and late SC12 superchargers?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 04-02-2010, 07:15 AM
  2. 1990 MX-83, replace with 7M or 1JZ
    By MX83-maybe in forum Tech and Conversions
    Last Post: 20-11-2007, 03:16 PM
  3. Small upgrade - SC12 onto 7AFE
    By birdie in forum Tech and Conversions
    Last Post: 18-10-2006, 09:32 PM
