alright been a while i know
but the engine specs are as follows
7mge(duh)
performance valve springs
2jz inlet and exhaust valves
slightly ported head (around the throat area manly and radiusing the short turn on all ports )
reground cams (268 advertised duration)
manly lash caps to adjust valve lash
1mm/.040 o/s pistons with 10 cc dish
arp rod bolts and head studs ajusa metal head gasket
king bearings .010" undersize on the pins and mains
bearing clearence .0015-.0018" all round
i have decked the block about 25 thou and 20thou off the head
the pistons at tdc are protruding 5 thou giving me 10.5:1 compression ratio
some pictures
lash caps
inlet port
