Results 1 to 5 of 5
Thread: Using 7MGE Injectors with 7MGTE ECU
    May 2008
    Default Using 7MGE Injectors with 7MGTE ECU
    Hi guys I’m going to be running a 7MGE with 7MGTE electronics(KARMEN VORTEX, COIL PACKS , GTE ECU, GTE Ignitor and Cam position sensor) now my issue is I will be using the 7MGE Injectors which I believe are High impedance correct? And originally the 7MGTE injectors were low impedance that’s why they need the resistor pack for the ecu. My question is will it be ok to run the 7MGE injectors with the 7MGTE ECU and how do I bypass the res pack plug or can I just leave it hanging there??? Before anyone says GTE ecu can run a 7MGE engine its just it will never see +boost. Bad luck for me I guess lol
    1992 - JZA70 STOCK - SOLD
    Default Re: Using 7MGE Injectors with 7MGTE ECU
    Dood...you will need to run the injectors that suit the ecu. i.e. the GTE ones, as the ecu will be set up for that size injector.
    Nov 2007
    Man 7mgte injectors on ebay for 60.00$. Check it out.
    leave the whole setup as is - as Cruzida has said elsewhere - the GTE ecu will have engine maps that cover vacuum and boost manifold pressure.
    Also - 7M-GTE MX73 is 100% correct and if you used undersized injectors, you could run the motor lean (even when not boosted) and bork it.
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    carlo, i still have a full set of 7mgte injectors laying around if you perhaps need a set? might make things easier for you, because running undersize will cause lean out.
    Mike
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
  1. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  2. max safe power on 1JZ with std injectors and ecu (with FCD)??
    By RORZ_JZA70 in forum Tech and Conversions
    Last Post: 14-08-2006, 11:59 AM
  3. Which injectors for which 4AGE bigport ECU
    By Grega in forum Tech and Conversions
    Last Post: 04-08-2006, 06:49 PM
  4. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
  5. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
