Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 79
Thread: My 7MGE Build
    Default Re: My 7MGE Build
    6m crank is the same stroke and should have less counterweights It is a lighter crank that has been reported to rev out better.
    Same capacity just lighter. Supposed to be not as smooth down low but reviver up top. I never noticed the lack of smoothness, in fact u could stand a coin on its edge on my rocker covers while the engine was running.
    Why are you waiting til the bottom end is together to work out ur compression? It will be too late to do anything about it by then….. also why do you need to know ur compression to get cams ground? All u need to know for that is how u want the engine to behave lol
    You should be able to work out comp now. u need to know bore, deck height, piston cc, head cc, HG thickness & bore. From memory standard GE pistons are a 12cc dish. For deck height u will need the crank and 1 x rod/piston in the block. What comp are you aiming for anyway?
    What was the MHG in the vrs kit like? Is it a metal one in the full gasket kit too?
    You got head studs too yeah?
    Never late in an x8
    Ajusa make a nice MHG that come in all their sets.
    Longer duration cams usually means late closing of the intake valves. This works well with high compression ratios. I would be inclined to go as big as possible on the intake cam and as high as you can reasonably go on the CR. Maybe upto 11:1 and 230 degrees duration at 50thou. Don't bother with the exhaust cam on the NA engine upgrading it just makes the car idle badly.
    Will sus out the gasket kit cheers. As good as a cometic or HKS jobie?
    I realise that longer duration cams lower the static comp ratio but working out wat compression u have THEN ordering cams to suit is (imo) the wrong way around. Get cams ground, then fiddle with the bottom end to get the comp up high enough to suit the grind.
    Either way, bigger is better and biggest is best lol.
    For the record my 280 regrinds are 228deg @ 50thou
    Never late in an x8
    Quote Originally Posted by andrew_mx83 View Post
    Sorry what i meant was im waiting to have all the bottom end parts machined than i'll dummy assembly it and than do what i have to get a decent comp ratio, (was thinking around (10.0:1 would be nice)
    The reason i need to know a comp ratio is because my cam grinder has asked all sorts of questions like diff ratio, manual or auto tranny comp ratio, what i ate for dinner last night etc
    Than he will grind the stock cams to what he thinks will suit me best (fyi camtech will be doing the cams i got a special price through work )
    ajusa hg i found was of very good quality and completely metal i ran the ajusa hg with arp head studs with my last 7m bhg and since than been strong as! the current 7m in the cressida cops a flogging i must admit and trouble free for over 7 months
    Ah ok I guess that’s one way of doing it….. my instructions to the cam grinder were simply “as big as u can go” lol
    how much is the full gasket kit costing (u can PM me if u like)? if u get looked after on them maybe u can put a lil on for urself and buy me one too
    bah 7 months is nothing, ive seen em go for years on an acl gasket *IF* the job was done properly
    Never late in an x8
  8. #38
    abit of an update i've finally had the time to get the block all machined, main tunnels were all closed and resized and the block is bored and honed will get it dummied next week and work out comp ratio
  9. #39
    Jun 2008
    victoria
    Default Re: Building a high comp n/a 7mge with standard ecu???
    cos its just not possible to go fast unless you have a turbo around here!
    Can't say i've ever seen a fast 7m-ge...Only so much you can do in a heavy car with a low n/a displacement motor.
    you can still make it fun however!, you'll want to adjust the timing, maybe a SAFC would be a good idea?
    Mk3 Supra - 7mgte, Haltech, T61 - 411rwhp @ 16psi
  10. #40
    when my new GE is finished i am fairly confident it will outrun a stockish 1jz without too much fuss...
    Never late in an x8
  11. #41
    i had a drive of my parts car which was a manual 7mge stock as(on e10 lol) , and it really had some go to it compared to my auto one which has the head rebuilt and a shit load of comp
    i now have my bearings, gaskets sets and studs so time to get this mofo built
  12. #42
    the 5 speed is the best thing u can do for a 7m
    the a340 just kills it unfortunately.... makes an amazing difference once u ditch it
    Never late in an x8
  13. #43
    [QUOTE=andrew_mx83;1079068]
    if its a series 2 it will ping under light load and really give you the shits
    /QUOTE]
    any reason why it occurs in series 2 x83's what about series 1 ?
  14. #44
    no idea why just series 2 mate.... just seems to be how it is.
    have you noticed it as well?
    Never late in an x8
  15. #45
    Convictania
    they're pretty tall aye.
    (same rough box/ratio as ls400 I think??)
  1. Slow Lasers :- AE82 BT 20v Build.
    By slow laser in forum Engine & Driveline Conversions
    Last Post: 10-02-2010, 07:10 PM
  2. Using 7MGE Injectors with 7MGTE ECU
    By JZA70R_92 in forum Tech and Conversions
    Last Post: 05-02-2009, 05:48 PM
  3. 7MGE and LPG
    By joecoolmk2 in forum Tech and Conversions
    Last Post: 02-05-2007, 12:04 AM
