Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 91
Thread: Cracking the Crank Pulley
  1. #46
    Default Re: Cracking the Crank Pulley
    Atleast bluepoint has lifetime warranty eh?
  2. #47
    Perth WA
    So does the Repco bar apparently. Unfortunatley the new Sidchrome bar will probably be replaced several times in it's 99year warranty?!
  3. #48
    Holy shit you broke the powerbar.
    So how are you getting the thread out of the crank now?
    Starting a new thread for removing the thread?
  4. #49
    ive sheared a crank bolt like that before torquing it up.... (4ag 140nm) wouldnt move an inch and the moment i tapped it with the drill to start hitting it with an ezy out it came out finger tight... you know that scene in the simpsons when homer swears so loudly that the whole town hears it and it zooms out to all these scenes across the town with his swearing echoing over.... that was me when i snapped it. :S
  5. #50
    Mechanic Grease Monkey jzx81mx83's Avatar
    W.A
    Pulled engine and box out, then seperated box and removed clutch. Chained flywheel up, and got the big hurter with old 1/2" socket and 22mm impact socket onto the job - brokeded it, swore!
    Next was a Powerbar as shown above - brokeded it too, other people swore:
    Final straw - I hired a Mongo (6'+ 100Kg mate with a Repco 1/2" breaker bar and a desire to kill it!), added the big hurter to the breaker bar, and strained like fuck - brokeded it - the bolt from it's bastard hold on the crank thread that is! Pulled the bolt out, doesn't show any signs of "loctite or similar" adhesive, but does show corrosion on the end. I can now progress with the timing belt change! FWIW, I expected the Repco bar to break too, but upon closer inspection, the drive peice is black/hardened steel, so I'll happily add one of these items to my toolkit - and recommend one to everyone else too.
    My thanks to DrNick for your help - it was greatly appreciated.
    Fucken Cars!
    hahahahahahhaa Yeah im 6.3 and 110kg lol and repco tools FTW Lol Cant beat the life time warranty to. So clint when u commin to get one from me ? There cheap lol
    Oh yeah my old man wasnt worried about the power bar im gettin a new one under warranty.
    cheers nick
    __________________________________________________
    89 GX81 Grande with manual single turbo 1jz
  6. #51
    Junior Member Backyard Mechanic DrNick's Avatar
    May 2008
    hahaha thank god for warranty i guess the tools werent built for the hardcore treatment they received in your hands lol.
    how many nm are those bolts meant to be btw, is it the 140nm posted above?
  7. #52
    Fark you broke a Powerbar! That would have been my recommendation if I had stumbled onto this thread earlier. I found the powerbar to be immensely useful to get the pulley off my cressy back when I owned it.
    244rwkw / 328hp @ 18psi
  8. #53
    At least you got it out & didn't find out that because some bastard had broken the keyway in the past, that they'd simply welded the pulley on!!
  9. #54
    Having same problem.
    Tried 1/2" drive rattle gun with impact socket - nothing.
    Tried breaker bar with extension smashing into a block of wood in the engine bay which is sitting on the chassis - nothing.
    Added loctite freeze to the above - nothing.
    Don't really want to heat it but not sure what next option should be? Car is auto so not sure how to stop engine from moving if I just use a breaker bar and hammer?
    QUICKEST 1JZ'S IN OZ
  10. #55
    is the engine getting pulled down ?
    you can pull a couple of plugs and fill the cylinders at BDC with oil and hydraulically lock the engine that will stop it turning.
    whilst i cant see how itd hurt the engine once you drained the oil back out (syringe and a hose) im still not sure id want to do it to an enigne im not pulling down.
  11. #56
    nope, not getting pulled down. I am not overly comfortable with the hydraulic locking idea either
  12. #57
    yeah, if its just engine oil in there i cant see why youd cause any damage given the cylinder pressure is obviosuly miles lower than what the rings, pistons, HG etc all have to deal with during combustion. but it still doesnt mean i love the idea ahahha
  13. #58
    Borrow 3/4 drive rattle gun and big compressor?
  14. #59
    Oct 2008
    TAS
    Quote Originally Posted by TooF
    I would NOT do this.! sounds like a bad idea.
    you've got to physically stop the crank from turning, with a manual u would just chuck it in 5th and put the brakes on, with an auto its harder but maybe you could take the starter out and jam a tire lever in against the ring gear?
    i WOULDN'T rely on the 'park' position cus u may break the pawl inside the box which would be BAD
    good luck!
  15. #60
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    when i did mine, i made a cylinder stopper (knocked guts out of old sparkplug and welded in a bolt), probably much worse than hydralic locking, but it did the job and car has driven at least 10,000 KM since without broken piston
  1. Crank Pulley Balance?
    By Talasas in forum Tech and Conversions
    Last Post: 23-10-2007, 02:09 PM
  2. 6MGE vs 5MGE crank pulley
    Last Post: 29-04-2007, 01:38 PM
  3. 4AGZE - EA Falcon Pulley Mod
    By TooF in forum Tech and Conversions
    Last Post: 15-05-2006, 12:23 PM
