well well well,
mental note to self, i hate my car! lol!
Thanks for all your help tonight chris and your dad's as well! now at least you know the tempermentality of my car LOL!
Ok i met up with chris and we had a look see at what was wrong he had a look at my coil packs and they seemed AOK! the vaccuum lines seemed to be fine. ran the diagnostics and SHOCK HORROR it came up with code 13!
in an attempt to aleviate this ( i can't even remember what it was ) think it was crank angle sensor or ecu or some shit! Chris mentioned that he had a JZX81 ecu a very short drive away.... drove away we did.
We hooked up the JZX81 ECU after giving chris a short tutorial on how ECU clips are meant to work LOL! we drove up a short hill just slowly crawling (about 2000rpms) no sweat on the other side of the hill it started to chug like a massey ferguson and i didn't like it so i pulled over. You should have seen the fuel smoke, i have never seen anything like it, if i had of had a lit smoke at the time i think there might have been an explosion totalling 3-4 suburban residential blocks!
We tried to reset and restart the car to see if the JZX81 would self learn and no go! it was like it was trying to physically turn the whole motor with none of the internals moving. I was panicking like i had seized the frigging thing (if you had my run of luck with a car then you always assume the worst possible scenario). Right f*ck the JZX81 ecu off and put the JZA70 ecu back in... still no cranky cranky... push start??? yeah right all it did was lock up the back wheels even at 15-25 k/hr down a hill in 3rd or 2nd! pulled over and stood there scratching our noodles. Chris' dad arrived with torch and assorted other goodies. He then started scratching his noodle.
What could it be? reset the JZA70 ecu... it turned maybe 3 turns then CLUNK that physical trying to twist the motor off its mounts noise again... reset it again.. maybe 4-5 turns.. right.....
reset it again and it wound freely... sweet now START YOU BASTARD!!!! after a few minutes of winding and pumping the accelermatrix it finally spluttered... seemed like it was running on 5 cylinders tho... another reset... same result
Ripped out the first coil pack, checked number 1 and 2 spark plug, dry as a bone and no black, where is the fuel? Put them back in another reset and all of a sudden it was running on 4 cylinders! with the motor running pulled the leads of 1/2 coil pack no difference... ah hah!
ran diagnostics luckily chris had the paper clip on him, code 14! chris called his lovely fiancee and she looked it up for us. ignition something or other, (ie coil pack or igniter) so that coil pack is giving us trouble EUREKA! screw driver to the rocker cover with a spark plug and there was plenty of spark! WTF? changed coil packs (i was carrying another full set in the car) and same deal, changed to another one... same deal WTF!!!!!!!!!!! we were stumped... what the hell is going on?
We tried the screwdriver trick in both sides of coil pack yes it has spark, then we fitted plugs to both, yes they had spark and because we didn't have the coil pack in they were nice and black therefore we have fuel... there were no stray cats in my intercooler that we could see so therefore we had air. What more do you need?
called my brother and he said do another reset. too easy. Always started fine ran for 3 seconds and then the idle dropped into a rough heap.
did it again to make sure...
this time maybe 3 cylinders were working, it was definitely worse!
again, and all of a sudden it wouldn't start.
Again the trusty paper clip helped us out, still code 14 hmmm
paper slip to bridge B+ and Fp and it ran! badly but it ran... ok now what the hell?
called my bro again and he said maybe your map sensor is kebabarooted... well i just so happened to have a spare one dangling around in the engine bay, no idea what it is for but i knew that the car did run on it very poorly.
reset the ecu left the fuel pump bridged to 12v+ and it ran the best it had since it stopped! well maybe the map sensor is fubard, lets try to get the bastard to run without the fuel pump.
unbridged it and reset the ecu, it still ran, due to it being the incorrect map sensor for the car it was overfuelling and being a pig won't rev over 4000rpms now! but it got my home!
MANY THANKS to chris davey and his father and his understanding fiancee for letting him out to help me even thought it was a school night!
now i think i need a new map sensor! where is the best place to get them? should i get one to suit the JZA70 loom? or the JZZ30 motor? or are they one and the same?
just thought i would let you guys know what was going on, oh and due to the map sensor the check engine light is constantly on!
thanks again for the help
matt![]()
