Page 9 of 33 FirstFirst ... 789101119 ... LastLast
Results 121 to 135 of 481
Thread: Celica Brake Upgrade
  1. #121
    Default Re: Celica Brake Upgrade
    i ~could~ probly get hold of some hilux 4 piston callipers if any1 gets stuck..... $200 delivered
    , mate im interested,
    how many can you get as a few here a looking for some,
    cheers, blake
  2. #122
    bastard! i just bought mine $250.
    argh oh well on my way .... wasa yall using for radiators?
    Black Betty >HERE!<
    (\__/)
  3. #123
    Wezelton Grease Monkey
    How come you guys dont seem to interested in the datsun (nissan) 4 piston caliper set up ? the xa6x celica/supra set up that cruzida has set up is sweet! and have you ever seen how many ra60/65 celicas are at the wreckers lol
    Bitch, come over here and have sex with Charlie Murphy..
    Im Rick James bitch!
  4. #124
    Quote Originally Posted by Wezelton
    Want to explaine whats involved in this setup dude?
  5. #125
    ive gots ra65 struts and steering knuckles. final test fitment will be this weekend to my parts car and ill see.
    but atm hilux/pug is tried and tested and cheaper from all acounts to ra60 upgrades.
    Black Betty >HERE!<
    (\__/)
  6. #126
    User Conversion King
    NWA
    Quote Originally Posted by TA-022
    i hope you like + camber because thats what you will be getting.
    i advise that you note which steering arm goes with which strut and swap them when you fit it to your car. you'll see what i mean when you look at the stuff. youll probly have to turn the stop bolts around as well. this will reduce the +camber by ~1/2 a degree i reckon
    this ~might~ make the steering a fraction harder if you swap the arms.
    hello
  7. #127
    NWA
    cheers, blake
    i might go see the bloke tomorow...ill get back to you
    hello
  8. #128
    NWA
    Quote Originally Posted by WindeX
    read read read!
    hello
  9. #129
    im reading that nissan upgrade, although im more inclined to go with a toyota upgrade for wanker reasons, it seems like a better option, cause its a whole lot easier to find a fucked nissan dori dori car, then it is to find a fucked work ute... also, wat is a z32? and cruzida made a plate to bridge the gap didnt he? u dont need sumfin liek that on this upgrade.. do u
    id rather avoid that stuff if possible
    but on another not, i got there. they had an ma70 MC but wanted 75$ for it. and i want the gz20 MC cause its a single reservior one. and i know 100% that it doesnt fault on the turbos of the 1g... ive been told that the twin reservoirs do however fault on the turbos...??? sum1 plz confirm...
    the struts they had plenty of, the brakes they had none of. the disks they had none of...
    oh, and yeh i know not to use 2nd hand parts. i dont intend to. i just wanted to test fit everything first. cause u guys make it all sound to easy, so i know im missing a whole bunch of stuff..
    JZA023
  10. #130
    well im still trying to work out how many mm i need to take the disc down by???
    one ive heard 15mm other ive heard maybe 3mm tops??
    got ya motor yet smokey? where ya get it from / getting it from?
    SSS quoted $950 wiring and ecu $1600 with w58. today.
    ill be buuying week or two
    Black Betty >HERE!<
    (\__/)
  11. #131
    yeh i got one, but i dunno how rooted it is. im gonna get the Head tested soon e nough. then ill wack a HG see if its got comp. hopefully it runs...
    i need a box but. so i might end up getting a package from sss anyway then use that engine for a fresh build up wif a few goodies . maybe we shud get two at once. see if they'll go down a few hund??? lol
    JZA023
  12. #132
    NWA
    Peugeot 604 front discs= 273mm
    just take them back to between 268 and 270
    hello
  13. #133
    sweet thanks brett.
    what box can i use behing a 1ggte? can i get away with 55/57
    cant splurge 4 a 58 unless it really needed. no plans to mod engine yet...stock and maybe a few psi more down the track but nothingmega.
    group buy at SSS ... im in
    Black Betty >HERE!<
    (\__/)
  14. #134
    NWA
    w55 should be fine. "ndgcpr" was running or might still be running a w55 behind his 1g in his soarer.
    and i have a slight hunch that my alledged w58 is in fact a w57.
    further more, "wilbo666" was running a w55 behind his 180rwkw MA61 for a while.
    i say just use a 55/7. in fact the place that sells gearboxes probly just call them all W58's
    you should ask them for some proof that it is a W58 .....ie. get them to count the ratio.
    ask them how many times the alledged w58 input spline rotates after the output spline is turned 100 times. if its a w58 then the the input spline will do 78.3 revolutions
    86.1 would be a w57
    85.00 would be a w55
    hello
  15. #135
    If you's have read that thread on the nissan 4 piston upgrade, you'll see there is little work. Addaptor plate, simply bolt in.
    Machine the hubs down a few mil and add on that ring, easy enough.
    Then just buy new rotors to suite Z32 (300ZX) /R32 Type M. Buy them blank if you can or even ask for 4 stud.
    (make sure you ask for custom 4 stud, stock R33 non turbo is close but slightly thinner and smaller)
    Finaly, buy studs 8mm longer than stock (rotor adds 8mm).
    Shizam! You got brakes to write off the local clubsport homo.
    I have this set up, havent put the rotors on yet but i have a pic. Just to tease!
    Wes.
    Pics.
    Wes.
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 02:29 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
